Some Observations While Using the KiwiSDR to Spot WSPR Stations [fixed in v1.242]
Gwyn Griffiths, G3ZIL gwyn@autonomousanalytics.com , Glenn Elmore, N6GN
n6gn@sonic.net, Rob Robinett, AI6VN, rob@robinett.us
Abstract
This article is intended to document some of our recent experiences using a KiwiSDR on WSPR and observed degradations of those spots when compared with other receiving and decoding techniques. Three techniques are examined: complete decode of WSPR stations by way of the KiwiSDR WSPR extension, use of the KiwiSDR to downconvert to an audio file which is decoded by a remote host, and for contrast a non-KiwiSDR path using an Apache Angelia SDR board. These comparisons show degradations in the two KiwiSDR paths both in terms of SNR of spotted stations and in number of stations spotted. Additionally these investigations have identified spurious signals associated with the downconversion process within the KiwiSDR.
[download article PDF below]
https://forum.kiwisdr.com/uploads/Uploader/03/1b0859f219235ed3276163cc3fa1e3.pdf
Glenn's testbench measurements suggest this weakness in the Kiwi may be correctable with SW and/or FW changes.
We are soliciting comments and suggestions on how to proceed.
This is what I find, using the 60kHz MSF time signal received @G0EZY:8073 (v1.241) tuned to 58.55 kHz and using three settings:
1) USB [1200 - 1700] -> like you are using for recording WSPR data
2) IQ [1200 -1700]
3) IQ [-6000 6000]
The first plot shows a zoom around the 60 kHz time signal where you can see 1Hz sidebands from the time pulses
The same spectrum in a wider frequency range is shown below. I would say that the USB[1200-1700] data contains (likely quantization) noise
Here you can see ~23Hz spikes in the IQ[1200-1700] data.
... and they are mirror images of the 60kHz signal (see the 1Hz harmonics due to the time pulses).
Do you have any insights into the other SNR problem? I suspect the CIC downconversion, but I know very little about digital signal processing.
It will take a more data gathering to confirm this but I'm quite confident that efforts by yourself and John have very significantly improved KiwiSDR performance, not just on WSPR but on all modes.
This is a big deal!
Thank you for all your work.
Although there is no immediately obvious difference between the reported S/N values, v 1.242 does seem to improve the consistency of the reports, with much less variation between spots of the same station in a similar time frame.
This observation may be purely co-incidental (due to variation in lightning storms etc.) but it does seem to be a positive improvement.
So a big thanks from me too.
A superseding update to the first article is attached. Here is the Summary:
improvement. We found evidence that in comparison to other SDRs the delivered SNR was not yet as good as it
might be. Spurious sidebands were generated within the KiwiSDR which resulted in false decodes on WSPR.
Extremely quick response by John Seamons and Christoph to the original data presented in Part 1 resulted in
elimination of the spurious spots as well as a large reduction in the SNR differences which had been observed
between the Apache SDR and KiwiSDR platforms.
Further measurements have revealed a remaining difference wherein spots of two closely spaced WSPR stations
on the KiwiSDR can result in the SNR of the weaker of the two being spuriously assigned an SNR higher than it
should be, typically to within 1.5dB of the stronger of the two. . These findings are presented in Part 2 of this
article.
https://forum.kiwisdr.com/uploads/Uploader/a9/f19334bbbcca28d72b85cb1f5be6ce.pdf
In this brief update I've looked at this issue in more detail using a KiwiSDR (v1.245, reporting as G3ZIL/K) and a direct conversion analogue receiver (G3ZIL) and I show that these Top-up errors are due to the use of an inadvisable combination of wsprd options in release 1.1g of kiwiwspr.sh.
AI6VN will be updating his script.
regards
Gwyn G3ZIL
https://forum.kiwisdr.com/uploads/Uploader/be/f051c5f8ce2ab6d1c827ad92ab02c7.pdf
