periodic drop-out with ver. 1.240 ? [fixed in v1.241]
Hi, since updating to 1.240 there are more or less peridiocally repeating drop-outs, having duration between a half and 2 seconds and a repetition rate between one and 15 minutes. It can be seen in S-Meter graph, see appended image. It isn't any static, I double-checked in comparision to other SDRs, I also made sure that it isn't any problem with antenna electronics by changing the antenna. Also, it shouldn't be a network problem, because it happens even when connecting KiwiSDR by cable (KiwiSDR-Router-PC).
Did anyone else noticed that problem?
Eckhard
https://forum.kiwisdr.com/uploads/Uploader/d8/2e958b194799adab006102e3cf378a.png
Eckhard
Using Chrome with Mac-OSx. Same issue occurs with Firefox.
Occurs on several KiwiSDR, I suppose they are all at 1.240 version
Eckhard
73, Bob
So I'll revert that change in today's update and hopefully that will fix it. We'll have to find some other solution for the WSPR guys.
