Upgrade between 1.235 and 1.236 appears to fail?
I just went to check in on my Kiwi and it looks like its gotten itself into an upgrade/build loop... I've seen this repeating itself for the last hour and a half, attempting to build, starting up 1.235 again and then attempting to upgrade again.. any ideas of things I should check? I can ssh into the debian user, disk appears to have 2.4g available, web interface appears to be listening, but no response back:
root@kiwisdr:/var/log# nc localhost 8073
GET /
Thanks
- Kevin, N3LGA
snip from my /var/log/messages
Sep 30 13:34:29 kiwisdr kiwid: 08:47:10.296 01.. 2 25690.95 kHz amn z5 "162.251.186.154" Los Gatos, California, USA (LEAVING after 1:01:38)
Sep 30 14:00:25 kiwisdr kiwid: 09:13:06.060 012. 2 GEOLOC: 95.246.95.135 sent no geoloc info, trying from here
Sep 30 14:00:25 kiwisdr kiwid: 09:13:06.918 012. 2 GEOLOC: extreme-ip-lookup.com/json/95.246.95.135
Sep 30 15:46:11 kiwisdr kiwid: 10:58:52.698 012. 2 14300.00 kHz usb z11 "w6ddu" 73.241.177.132 Napa, California, USA (ARRIVED)
Sep 30 15:46:22 kiwisdr kiwid: 10:59:03.914 012. 2 14300.00 kHz usb z11 "w6ddu" 73.241.177.132 Napa, California, USA (LEAVING after 0:00:21)
Sep 30 20:48:09 kiwisdr kiwid: 16:00:50.003 012. 2 14072.20 kHz cw z6 "73.15.156.50" Santa Rosa, California, USA (ARRIVED)
Sep 30 20:49:37 kiwisdr kiwid: 16:02:18.904 01.. 2 27385.00 kHz lsb z5 "73.15.156.50" Santa Rosa, California, USA (LEAVING after 0:01:40)
Sep 30 21:57:58 kiwisdr kiwid: 17:10:39.807 012. 2 740.00 kHz am z6 "91.77.59.232" Moscow, Russia (ARRIVED)
Sep 30 21:58:09 kiwisdr kiwid: 17:10:50.047 01.. 2 13087.00 kHz usb z6 "91.77.59.232" Moscow, Russia (LEAVING after 0:00:22)
Sep 30 22:57:45 kiwisdr kiwid: 18:10:26.037 012. 2 GEOLOC: 174.221.129.183 sent no geoloc info, trying from here
Sep 30 22:57:51 kiwisdr kiwid: 18:10:32.157 012. 2 GEOLOC: ipapi.co/174.221.129.183/json
Sep 30 22:59:40 kiwisdr kiwid: 18:12:21.676 012. 2 1000.00 kHz am z4 "174.221.129.183" Chicago, Illinois, USA (ARRIVED)
Sep 30 23:02:05 kiwisdr kiwid: 18:14:46.395 01.. 2 740.00 kHz am z4 "174.221.129.183" Chicago, Illinois, USA (LEAVING after 0:02:37)
Oct 1 00:01:45 kiwisdr kiwid: 19:14:26.039 012. 2 GEOLOC: 95.246.95.135 sent no geoloc info, trying from here
Oct 1 00:01:45 kiwisdr kiwid: 19:14:26.621 012. 2 GEOLOC: ipapi.co/95.246.95.135/json
Oct 1 02:00:25 kiwisdr kiwid: 21:13:06.041 012. 2 GEOLOC: 95.246.95.135 sent no geoloc info, trying from here
Oct 1 02:00:25 kiwisdr kiwid: 21:13:06.791 012. 2 GEOLOC: extreme-ip-lookup.com/json/95.246.95.135
Oct 1 04:42:05 kiwisdr kiwid: 23:54:46.050 01.. UPDATE: check scheduled
Oct 1 04:42:05 kiwisdr kiwid: 23:54:46.064 01.. UPDATE: checking for updates
Oct 1 04:42:06 kiwisdr kiwid: 23:54:47.098 01.. UPDATE: version changed, current 1.235, new 1.236
Oct 1 04:42:06 kiwisdr kiwid: 23:54:47.101 01.. UPDATE: building new version..
Oct 1 04:42:25 kiwisdr kiwid: 00:00:00.579 KiwiSDR v1.235 --------------------------------------------------------------------
Oct 1 04:42:25 kiwisdr kiwid: 00:00:00.583 compiled: Sep 30 2018 04:42:43
Oct 1 04:42:25 kiwisdr kiwid: 00:00:00.586 -debian 8
Oct 1 04:42:25 kiwisdr kiwid: 00:00:00.586 /etc/debian_version 8.5
Oct 1 04:42:25 kiwisdr kiwid: 00:00:00.586 background mode: delaying start 30 secs...
Oct 1 04:42:55 kiwisdr kiwid: 00:00:30.669 reading configuration from file /root/kiwi.config/kiwi.json: 139 tokens
Oct 1 04:42:55 kiwisdr kiwid: 00:00:30.673 reading configuration from file /root/kiwi.config/admin.json: 83 tokens
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.060 serial number from EEPROM: 1362
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.131 reading configuration from file /root/kiwi.config/dx.json: 7084 tokens
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.134 887 dx entries
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.148 .... firmware: SDR_4RX_4WF
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.150 .... firmware: rx_chans=4 wf_chans=4
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.153 .... firmware: NRX bufs=4 samps=170 loop=85/85 rem=0/0
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.153 .... firmware: NWF xfer=9 samps=911 rpt=50 loop=18 rem=11
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.154 .... listening on default port 8073/8073 for "openwebrx"
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.156 .... webserver for "openwebrx" on port [::]:8073
Oct 1 04:42:56 kiwisdr kiwid: 00:00:31.386 .... ### using SPI_DEV
Oct 1 04:42:57 kiwisdr kiwid: 00:00:32.160 .... FPGA version 1
Oct 1 04:42:57 kiwisdr kiwid: 00:00:32.620 .... using DC_offsets: I -0.020000 Q -0.020000
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.025 01.. 1 14097.10 kHz usb z0 "WSPR-autorun" 127.0.0.1 (ARRIVED)
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.028 01.. 0 7040.10 kHz usb z0 "WSPR-autorun" 127.0.0.1 (ARRIVED)
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.032 01.. UPDATE: check scheduled (startup)
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.038 01.. UPDATE: checking for updates
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.856 01.. DDNS: public ip 24.130.58.48
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.859 01.. DDNS: lat/lon = (37.369700, -122.021400)
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.862 01.. DDNS: private IPv4 <10.0.1.42> 0x0a00012a /24 0xffffff00
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.862 01.. DDNS: private IPv6 <2601:647:4b00:b00:8a4a:eaff:fee0:13ab> /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Oct 1 04:43:01 kiwisdr kiwid: 00:00:36.863 01.. DDNS: private IPv6 LINK-LOCAL /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Oct 1 04:43:02 kiwisdr kiwid: 00:00:37.069 01.. UPDATE: version changed, current 1.235, new 1.236
Oct 1 04:43:02 kiwisdr kiwid: 00:00:37.071 01.. UPDATE: building new version..
Oct 1 04:43:20 kiwisdr kiwid: 00:00:00.580 KiwiSDR v1.235 --------------------------------------------------------------------
Oct 1 04:43:20 kiwisdr kiwid: 00:00:00.583 compiled: Sep 30 2018 04:42:43
Oct 1 04:43:20 kiwisdr kiwid: 00:00:00.586 -debian 8
Oct 1 04:43:20 kiwisdr kiwid: 00:00:00.586 /etc/debian_version 8.5
Oct 1 04:43:20 kiwisdr kiwid: 00:00:00.586 background mode: delaying start 30 secs...
Oct 1 04:43:50 kiwisdr kiwid: 00:00:30.669 reading configuration from file /root/kiwi.config/kiwi.json: 139 tokens
Oct 1 04:43:50 kiwisdr kiwid: 00:00:30.673 reading configuration from file /root/kiwi.config/admin.json: 83 tokens
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.060 serial number from EEPROM: 1362
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.132 reading configuration from file /root/kiwi.config/dx.json: 7084 tokens
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.135 887 dx entries
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.149 .... firmware: SDR_4RX_4WF
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.151 .... firmware: rx_chans=4 wf_chans=4
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.154 .... firmware: NRX bufs=4 samps=170 loop=85/85 rem=0/0
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.154 .... firmware: NWF xfer=9 samps=911 rpt=50 loop=18 rem=11
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.155 .... listening on default port 8073/8073 for "openwebrx"
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.159 .... webserver for "openwebrx" on port [::]:8073
Oct 1 04:43:51 kiwisdr kiwid: 00:00:31.389 .... ### using SPI_DEV
Oct 1 04:43:52 kiwisdr kiwid: 00:00:32.160 .... FPGA version 1
Oct 1 04:43:52 kiwisdr kiwid: 00:00:32.620 .... using DC_offsets: I -0.020000 Q -0.020000
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.015 01.. 1 14097.10 kHz usb z0 "WSPR-autorun" 127.0.0.1 (ARRIVED)
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.018 01.. 0 7040.10 kHz usb z0 "WSPR-autorun" 127.0.0.1 (ARRIVED)
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.022 01.. UPDATE: check scheduled (startup)
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.028 01.. UPDATE: checking for updates
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.805 01.. DDNS: public ip 24.130.58.48
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.808 01.. DDNS: lat/lon = (37.369700, -122.021400)
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.811 01.. DDNS: private IPv4 <10.0.1.42> 0x0a00012a /24 0xffffff00
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.811 01.. DDNS: private IPv6 <2601:647:4b00:b00:8a4a:eaff:fee0:13ab> /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Oct 1 04:43:56 kiwisdr kiwid: 00:00:36.811 01.. DDNS: private IPv6 LINK-LOCAL /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Oct 1 04:43:57 kiwisdr kiwid: 00:00:37.060 01.. UPDATE: version changed, current 1.235, new 1.236
Oct 1 04:43:57 kiwisdr kiwid: 00:00:37.063 01.. UPDATE: building new version..
Oct 1 04:44:15 kiwisdr kiwid: 00:00:00.579 KiwiSDR v1.235 --------------------------------------------------------------------
Oct 1 04:44:15 kiwisdr kiwid: 00:00:00.583 compiled: Sep 30 2018 04:42:43
Oct 1 04:44:15 kiwisdr kiwid: 00:00:00.586 -debian 8
Oct 1 04:44:15 kiwisdr kiwid: 00:00:00.586 /etc/debian_version 8.5
Oct 1 04:44:15 kiwisdr kiwid: 00:00:00.586 background mode: delaying start 30 secs...
Oct 1 04:44:45 kiwisdr kiwid: 00:00:30.669 reading configuration from file /root/kiwi.config/kiwi.json: 139 tokens
Oct 1 04:44:45 kiwisdr kiwid: 00:00:30.673 reading configuration from file /root/kiwi.config/admin.json: 83 tokens
Oct
GET /
Thanks
- Kevin, N3LGA
Oct
Hundreds of other Kiwis have updated just fine.
I need more information. Do you know how to login to your Kiwi using ssh (Linux/Mac) or PuTTY (Windows)? If so, can you try these commands and let me know what error messages occur after the build starts:
cdp
mst (stops Kiwi server running in background)
k (runs server in foreground)
If this doesn't work type "up" to do a manual build and see if that clears it up.
I read this thread and tried the cdp, mst, then k commands. I didn't see any error type messages, but I was back to the "unable to connect message".
I then issued the 'up' command, and after the rebuild I seem to be working on 236 now.
I hope this helps. What is the difference between the k and up commands?
Mike N8OOU
I will keep trying to revive it, but any suggestions would be welcome...
Oct 1 13:33:15 kiwisdr kiwid: 00:00:35.813 01.. UPDATE: check scheduled (startup)
Oct 1 13:33:15 kiwisdr kiwid: 00:00:35.848 01.. UPDATE: checking for updates
Oct 1 13:33:15 kiwisdr kiwid: 00:00:36.488 01.. DDNS: public ip ICENSOREDTHIS
Oct 1 13:33:15 kiwisdr kiwid: 00:00:36.491 01.. DDNS: lat/lon = (34.213300, -118.880000)
Oct 1 13:33:15 kiwisdr kiwid: 00:00:36.494 01.. DDNS: private IPv4 0xc0a80188 /24 0xffffff00
Oct 1 13:33:15 kiwisdr kiwid: 00:00:36.494 01.. DDNS: private IPv6 LINK-LOCAL /64 ff:ff:ff:ff :ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Oct 1 13:33:16 kiwisdr kiwid: 00:00:36.897 01.. UPDATE: version changed, current 1.235, new 1.236
Oct 1 13:33:16 kiwisdr kiwid: 00:00:36.900 01.. UPDATE: building new version..
Oct 1 13:34:33 kiwisdr rsyslogd-2007: action 'action 17' suspended, next retry is Mon Oct 1 13:36:03 2018 [try http://www.rsyslog. com/e/2007 ]
Oct 1 13:40:40 kiwisdr rsyslogd-2007: action 'action 17' suspended, next retry is Mon Oct 1 13:42:10 2018 [try http://www.rsyslog. com/e/2007 ]
Oct 1 13:50:45 kiwisdr rsyslogd-2007: action 'action 17' suspended, next retry is Mon Oct 1 13:52:15 2018 [try http://www.rsyslog. com/e/2007 ]
Upgrade is now proceding, let's hope it finished OK this time
I'll fix it in today's update. But the issue now is that you'll either have to temporarily turn off WSPR auto-run or go through the manual update procedure one more time to get past this problem.
However I have no idea how to implement any of the fixes as I know nothing about Linux or the commands etc. mentioned as I am into radio not software so any suggestions as to what I need to do would be appreciated. I expect to be home tomorrow or Thursday at some point.
You need to connect to your KiWi by means of a terminal program such as PuTTY.
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Setup the KiWi IP address in PuTTY and select Port 22.
Select SSH and connect.
When you connect you should get a terminal window apear and show a prompt from your KiWi to login. Use the user name "root"
You should then get a command line cursor.
type cdp and press enter
then type up and press enter
A whole load of stuff should be listed in the terminal window and after about 5 mins the command prompt will reappear.
Leave it for a short while and the KiWi should have restarted, updated and be back to normal.
What worked for me
George,
M1GEO.com
Cheers, Chris.
Many thanks for the information I will give is a try when I get home.
Also thanks to John for the offer to fix it via Teamviewer. If I cannot get it sorted using the instructions from Martin i will be in touch.
Regards
John - G4HPW / W1JCT
Had a problem at first with Martin's cpd command returning a not recognised message but a bit of reading this thread identified it should be cdp..
Once that was resolved all went as per instructions. [I edited his post to now say "cdp" -jks]
Regards
PK.
