TDoA known location markers
in TDoA topics
Is it possible (or considered for later versions) to have the ability to display the known transmitter location markers on the TDoA combined/ results map? If we used different markers for the predicted TDoA location and the known transmitters it may be possible to present both on the map? I think it would help when you are trying to evaluate the likely location of a TXM.
Dave M0TAZ
Dave M0TAZ
Before you start the process single-click on a reference station so its information is copied into the field at the lower left of the TDoA control panel. Or optionally type your own reference info, format: lat lon id description. Then the result maps will show that info in a marker in addition to the "most likely" position computed. Also, if you're specifying everything from the URL, you can just list the reference station id to have it pre-selected. Just like the Kiwis to use are specified. See below. Using the Google map ruler we can see the difference in computed to actual location is a bit over 20 km.
https://forum.kiwisdr.com/uploads/Uploader/bd/8d31aa01fe4ac9efaa3bb5aef77090.png
It can be experimentally tested and found true within the experimental acuracy of the setup.
