V 1.214 WSPR-autorun on 8 channels not so effective as on 4 channels [known limitation]
Hello,
it seems that WSPR-autorun decoded on 8 channels less spots per channel or is less sensitive then WSPR-autorun on 4 channels.
Can anybody confirm this?
Vy73 de Wernererich
Vy73 de Wernererich
That's why Rob's solution feeding 8 channels of IQ via kiwirecorder to one of the newer multi-core Raspberry Pis works so well. There is no cpu bottleneck and full decoding takes place without anything being "left on the table".
But it's always possible there is a problem between 4 and 8 channel modes. My antenna is down at the moment. What we really need is for someone to run an experiment where one antenna feeds two Kiwis. One running 4 auto-run sessions in 4 channel mode and the other running 4 auto-run sessions in 8 channel mode and see if the decode counts disagree significantly.
73 de Wernererich
I think that maybe we are all loosing sight of what the KiWi was originally designed to do and what it is now capable of.
A while ago John posted a link https://en.wikipedia.org/wiki/No_good_deed_goes_unpunished
Which I think nicely sums up the situation today. John has managed to achieve a fantastic amount of functionality in the KiWi, but unfortunately human nature being what it is, this just leads to us all (well me certainly) tending to want even more, no matter how technically difficult and no matter how much Scotty would have protested that Ye cannae change the laws of physics.
I suspect that we have now well gone past the point of 'diminishing returns' https://en.wikipedia.org/wiki/Diminishing_returns so perhaps we need to be more realistic about what is desirable, possible, or what is likely to cause John to "spontaneously combust" https://en.wikipedia.org/wiki/Spontaneous_human_combustion if we carry on urging him to try and do even more with less.
My apologies to John, for all my reduculous requests and crazy suggestions, and I hope that's enough metaphor's in one posting for folks to consider :-)
I think the built in WSPR decoder is adequate for casual users. It's a bit like the FSK and Fax decoders. They are perfectly OK for a quick 'look see' but serious users would probably use an external decoder fed via a sound-card loop-back or VAC.
At lest there is a good technical workaround for WSPR and 'serious' users now have the option of being able to use up to 8 RX channels too, which I think is a very good solution.
Thanks for the clarification.
73 Wernererich
Over the same time period (2013-) the Beaglebone Black (and variants) have all used a TI Sitara AM3358/9 single-core Cortex-A8 at mostly 1GHz. There is the BeagleBoard-X15 (US $270) that uses the AM5728 dual-core Cortex-A15 @ 1.5GHz. It is not physically compatible with the BBB. And at that price it doesn't matter.
So both the BeagleBone and TI are behind the curve. The Broadcom parts don't have Ethernet MACs for some reason, but otherwise kudos to them.
I tested the kiwi over night with only 6 WSPR channels and lo and behold, the result was much better.
73 Wernererich
I wrote up the details in case anyone was interested in the BeagleBone Black/Green vs RPi story. The situation was reversed in 2013 when work began on the Kiwi. The RPi-A1 was terrible and the BBB was the clear winner. This improved with the lower cost BBG by the time we got to the Kickstarter and Seeed taking over manufacturing. But things started changing in late 2016 with the RPi-B2/v1.2
It has been a breath of fresh air to be able to see the RF world from so many devices. There is a fair possibility that with the increasing CPU and interface speeds EMI becomes more of an issue and you may have ended up having to avoid certain RPi versions or peripherals that just can't be used on the BB.
Also the myriad software platforms available on the RPi would have meant constantly fielding the "can it run at the same time as software X, on OS Y version 0.4.3.8?".
I think there is something to be said for just enough for the task.
