TDoA doesn't work with a mix of 4ch and 8ch Kiwis [fixed in v1.214]
Hi all. I can get sane TDoA results if I use all 4ch Kiwis, or all 8ch Kiwis, but not with a mixture of the two types.
Richard G4DYA
Richard G4DYA
@G8JNJ or @jks : could you make an IQ recording with timestamps from a 1PPS (better 5PPS or more) input signal? Then I or someone else can measure the new offset.
OK will do.
Can you remind me of the kiwirecorder.py syntax for the recording command string. It's a while since I last used it.
I'm out today but I've left a KiWi in 8ch mode with the PPS marker running. GPS 1PPS is fed via 20m of coax.
http://g8jnj.proxy.kiwisdr.com:8073
The fix I made was to simply divide NRX_CHANS by 2 for RX4 mode so that it's equal to the value used for RX8 in the timestamp code. I don't understand this code fully, but it seems to have resolved the problem. Now there is also a tuned constant "gps_delay" which I think was measured empirically using the 1PPS setup if I remember correctly. This might have to be adjusted.
