TDoA Successes
List your results here
* Pinpointing several Bulgarian and North Korean embassies in Europe
* Locating the unid parallel 6-tone MFSK system on 7674, 10222, 12130, 14462, 16115, 17456 in Frankfurt area
Ron - KA7U
https://forum.kiwisdr.com/uploads/Uploader/7b/80fa28d3dcd308246b40e051568882.png
OK, that did a much nicer result. Very nice! I did check the results and found the triangulation point to be approximately 70 miles north of the transmitter towers. I suppose KiwiSDR location information could be inaccurate and other reception anomalies could affect the accuracy as well. Still 70 miles is pretty close.
Ron - KA7U
When zoomed in the site was within the centre circle.
China Radio International Kashi-Saibagh (Coordinates: 39°21'40"N 75°44'43"E).
Dirk SWLJO43
13760 kHz, Kujang (200 kW)
It's a Russian CIS-12 signal on 11175KHz.
Ron - KA7U
There are problems when stations cross 180 deg even when the map range doesn't. I haven't had time to look into it in detail yet.
http://wikimapia.org/#lang=en&lat=51.807434&lon=3.893216&z=16&m=b
http://wikimapia.org/#lang=en&lat=39.364032&lon=75.713739&z=14&m=b
53.677, 7.612
Chayka transmitter Slonim, 2nd station of RSDN-3 53.132, 25.396111
Wilhelmshaven is the result of a TDoA of a STANAG transmission on 12176KHz USB. Unfortunately I didn't save the setup.
Istra near Moscow 55°53'03.0"N 36°57'13.0"E
https://www.cia.gov/library/readingroom/docs/CIA-RDP78T04563A001000010071-8.pdf
More Russian sites listed here.
https://www.cia.gov/library/readingroom/docs/CIA-RDP78T05162A000200010022-5.pdf
STANAG on 12668KHz using
http://southwest.ddns.net:8073/?f=12668.41iqz8&pbw=1620&ext=tdoa,lat:43.36,lon:2.17,z:9,map:1,DF0KL,CS5SEL,G8JNJ,LA3SP,SA0CAM,SV8RV,FUG
Ground Station ID 1 SAN FRANCISCO - CALIFORNIA
Longitude 121 45 34 W Latitude 38 22 48 N
Ground Station ID 2 MOLOKAI - HAWAII
Longitude 157 10 46 W Latitude 21 10 47 N
Ground Station ID 3 REYKJAVIK - ICELAND
Longitude 21 50 59 W Latitude 64 4 47 N
Ground Station ID 4 RIVERHEAD - NEW YORK
Longitude 72 38 22 W Latitude 40 52 47 N
Ground Station ID 5 AUCKLAND - NEW ZEALAND
Longitude 174 48 35 E Latitude 37 1 10 S
Ground Station ID 6 HAT YAI - THAILAND
Longitude 100 23 24 E Latitude 6 56 23 N
Ground Station ID 7 SHANNON - IRELAND
Longitude 8 55 46 W Latitude 52 43 48 N
Ground Station ID 8 JOHANNESBURG - SOUTH AFRICA
Longitude 28 12 35 E Latitude 26 7 46 S
Ground Station ID 9 BARROW - ALASKA
Longitude 156 46 46 W Latitude 71 18 0 N
Ground Station ID 11 ALBROOK - PANAMA CITY
Longitude 79 32 59 W Latitude 8 58 12 N
Ground Station ID 13 SANTA CRUZ - BOLIVIA
Longitude 63 7 46 W Latitude 17 40 11 S
Ground Station ID 14 KRASNOYARSK - RUSSIA
Longitude 92 18 0 E Latitude 56 6 0 N
Ground Station ID 15 AL MUHARRAQ - BAHRAIN
Longitude 50 39 0 E Latitude 26 16 12 N
Ground Station ID 16 AGANA - GUAM
Longitude 144 48 0 E Latitude 13 28 11 N
Ground Station ID 17 CANARIAS - SPAIN
Longitude 15 23 23 W Latitude 27 56 59 N
56.1228, 10.2068
https://forum.kiwisdr.com/uploads/Uploader/c1/34801d613bbfc0e055bdd6a0f6b2b9.png
52.9192, 4.7436
http://southwest.ddns.net:8073/?f=6358.62iqz8&pbw=3160&ext=tdoa,lat:52.18,lon:4.21,z:6,G8JNJ,G0LUJ,F1JEK,DF0KL,DC9FD
PBC also annotated on results map.
DHO26 German Navy, Near Rostock / Marlow, Germany 54.1438,12.5504
Note - Not operating on LF 53KHz for site reference only
Ron - KA7U
