IMPORTANT: sdr.hu API key privacy policy acceptance required by May 25
jksjks
edited July 2018 in KiwiSDR Discussion
In order to continue to use your API key issued by sdr.hu you must respond to an email they've sent by May 25 (sample below). The API key is used to register your Kiwi on sdr.hu and also to use the KiwiSDR proxy service.
In order to continue using your API key after 25 May, you need to add a password to your account, and accept the new Terms of Use and Privacy Policy here:
https://sdr.hu/forgot?token=...
Please accept it before May 24 23:00 CEST.
If you can't make it by that time, then please register again at SDR.hu to receive a new API key.
I'm sorry for the inconvenience. I have to do this to make sure I comply with the GDPR (new laws about personal data in the EU).
(The password is required so that you can log in to the site, view, change and delete your personal data.)
Please contact me in case of any problem.
VY 73!
Andras, HA7ILM
sdr.hu
  • Is there some kind of backup in case not all KiwiSDRs obtain the new you key?
    Does rx.linkfanel.net rely on sdr.hu?
    It would be a pity if because of this KiwiSDRs became invisible.
  • Is there some kind of backup in case not all KiwiSDRs obtain the new API key?
    Nothing on the Kiwi side is lost. The worst that might happen is that you'll need to register for a new API key from sdr.hu to continue being listed there. The kiwisdr.com proxy will continue to work using existing API keys.
    No
  • Looking for a Kiwi not currently listed on sdr.hu? Try http://kiwisdr.com/public and http://rx.linkfanel.net
    Christoph
