KiwiSDR on Beaglebone Green Wireless...
wanting to eliminate signal loss in a long (100m) koax cable and to minimize the QRM/noise generated by all the stuff in my house I decided to try to use the wireless version of the beaglebone green instead.
As he board had stuff sticking up longer, I procured extension headers to get the KiwiSDR cape 15mm higher up.
After installing the missing software packages to get the wireless interface configured I got the board to connect to my WiFi.
However, the kiwi daemon wont start:
Sun Jan 7 14:18:31 2018 0:00:00 .... KiwiSDR v1.2 --------------------------------------------------------------------
Sun Jan 7 14:18:31 2018 0:00:00 .... compiled: Aug 10 2016 21:09:53
Sun Jan 7 14:18:31 2018 0:00:00 .... using 97 of 128 tokens
Sun Jan 7 14:18:31 2018 0:00:00 .... reading configuration from file /root/kiwi.config/kiwi.json
Sun Jan 7 14:18:31 2018 0:00:00 .... serial number from EEPROM: 1994
Sun Jan 7 14:18:31 2018 0:00:00 .... using 7052 of 8192 tokens
Sun Jan 7 14:18:31 2018 0:00:00 .... reading configuration from file /root/kiwi.config/dx.json
Sun Jan 7 14:18:31 2018 0:00:00 .... 883 dx entries
Sun Jan 7 14:18:31 2018 0:00:00 .... TASK: jmp_buf demangle key 0x0f9b2f16
Sun Jan 7 14:18:31 2018 0:00:00 .... listening on port 8073 for "openwebrx"
Sun Jan 7 14:18:31 2018 0:00:00 .... webserver for "openwebrx" on port 8073
Sun Jan 7 14:18:31 2018 0:00:00 .... DEVIO setup SPI0_SCLK 0_2 OUTPUT
Sun Jan 7 14:18:31 2018 0:00:00 .... PMUX check GPIO 0_2 P9-22 eeprom 88/0x58 has attr 0x30 <FAST, RX, PU, m0>
Sun Jan 7 14:18:31 2018 0:00:00 .... DEVIO setup SPI0_MISO 0_3 INPUT
Sun Jan 7 14:18:31 2018 0:00:00 .... PMUX check GPIO 0_3 P9-21 eeprom 90/0x5a has attr 0x30 <FAST, RX, PU, m0>
Sun Jan 7 14:18:31 2018 0:00:00 .... DEVIO setup SPI0_MOSI 0_4 OUTPUT
Sun Jan 7 14:18:31 2018 0:00:00 .... PMUX check GPIO 0_4 P9-18 eeprom 92/0x5c has attr 0x10 <FAST, PU, m0>
Sun Jan 7 14:18:31 2018 0:00:00 .... DEVIO setup SPI0_CS0 0_5 OUTPUT
Sun Jan 7 14:18:31 2018 0:00:00 .... PMUX check GPIO 0_5 P9-17 eeprom 94/0x5e has attr 0x10 <FAST, PU, m0>
Sun Jan 7 14:18:31 2018 0:00:00 .... GPIO setup SPI0_CS1 1_19 OUTPUT initial=1
Sun Jan 7 14:18:31 2018 0:00:00 .... PMUX check GPIO 1_19 P9-16 eeprom 158/0x9e has attr 0x27 <FAST, RX, OE, PD, m7>
Sun Jan 7 14:18:31 2018 0:00:00 .... GPIO setup GPIO0_30 0_30 BIDIR initial=Z
Sun Jan 7 14:18:31 2018 0:00:00 .... PMUX 0_30 got 0x37 != want 0x2f
Sun Jan 7 14:18:31 2018 0:00:00 .... PANIC: "check_pmux" (platform/beaglebone_black/peri.cpp, line 101)
Any Ideas how to get past this Y/ fix this?
Jonas - SM4VEY
