GPS no longer finding signals [bad GPS antenna]
My Kiwi GPS lost the ability to track satellites. The status page shows sporadic signals for one or two satellites, but it no longer locks to even one. I have changed the antenna with no improvement and the antenna remains outdoors mounted on a pie pan.
You should be able to get away with it if the antenna has a high enough gain amplifier to overcome the cable losses without degrading the Signal to Noise ratio.
The S/N ratio is generally set by the device used as the amplifier in the GPS antenna, which should be as low noise as possible. Above a minimum value the gain figure doesn't really matter, it's only there to make up for cable losses. Once you overcome the cable loss, adding more gain will not improve the S/N ratio.
It's exactly the same with satellite TV reception. The Ku band 11GHz is converted down to L-Band 1-2GHz (the same frequency range as GPS signals) by means of the LNB (Low Noise Block) down convertor that is mounted at the dish focus. The LNB typically has 50dB gain so that you can run quite long lengths of coax before the attenuation becomes excessive.
For example, I use a professional outdoor 'bullet' GPS antenna which feeds four GPS receivers after being split (with a passive satellite TV L-Band splitter with 6dB loss) via 30m (approx 100ft) of RG6 foam filled foil and braid screened coax, and it all works perfectly OK.
A lot of the magnetic mount GPS antennas with RG174 cable generally only have enough gain to overcome the loss associated with the attached very thin RG 174 coax. Some have more gain than others and as a result will work with longer coax cable extensions, but as they all look the same it can be a bit of a gamble.
https://smile.amazon.com/gp/product/B00LXRQY9A/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I don't know what the gain was of the original antenna, but this antenna works through the approximate 8 dB of additional loss of the 100' of CAT-6. Your splitter suggestion is intriguing as I plan to install 6 or more Kiwis at the KPH receive site later this month, and I would rather not run extension cords to antennas for each Kiwi. I expect you would use a splitter which blocks DC from all but one of the splitter outputs.
Yes, you would need to use an active splitter an 8 way passive would have about 12dB through loss which is likely to be excessive.
General rule of thumb (approximate) attenuation when using cheap satellite TV passive splitters:-
2 ways 3.5dB
4way 6.5dB
6 way 8.5dB
8way 12.5dB
12way 16dB
Martin G8JNJ
