30 dB in line amplifier [Not Answered, sorry I accidentally hit accept on the comment.]
Is it possible to use a 30dB LNA, High Gain, low noise amplifier between my antenna and my KiwiSDR? I dont want to fry my Kiwi so any advice would be appreciated.
Thank you!!
Kyle
Here is the device in question for reference https://www.amazon.com/HiLetgo-0-1-2000MHz-Wide-Amplifier-Noise/dp/B01N2NJSGV/ref=sr_1_fkmr1_2?ie=UTF8&qid=1515014083&sr=8-2-fkmr1&keywords=Hiletgo+Lna+amp
Thank you!!
Kyle
But I havent installed it yet.
As to the amplifier, the gain isn't so much a factor as how much power it can put out. If you have no transmitters nearby it shouldn't be a problem. If you do, what ever couples from it's antenna into the receive antenna will be amplified. The amplifier you have the link for says max output is +10 dBm. That is a pretty big signal for a receiver but I don't believe it will harm the Kiwi.
Steve KD2OM
Steve KD2OM
