v1.154 released: New user interface, Navtex extension
Restart to get it now, or wait for the automatic update starting at 0200 UTC (updates only if your Kiwi has no active connections).
Copied from the CHANGE_LOG file:v1.154 Jan 2, 2018
New Navtex extension.
Major user interface changes:
New option tab user interface for lower right control panel.
Removed lower left status panel. Replaced with the new "Users" and "Stats" option tabs.
Next/previous history buttons next to frequency entry box.
If using a keyboard press return key to select displayed frequency.
Otherwise prior frequency will return after three seconds.
Doesn't really work yet for mobile devices.
Added numeric dBm value to S-meter.
Added classic LMS denoiser and autonotch to audio tab. Filter controls on extension panel.
The LMS filters are not a panacea for all filtering problems.
They are tricky to adjust and don't work in all situations.
The presets are a work-in-progress.
Added audio mute icon/button to right of spectrum button (renamed "Spec" to fit).
WF option tab
Number after "WF" on option tab button is current zoom level, e.g. "WF10"
"Auto Scale" button: automatically sets WF min/max.
Best when there are a range of signal levels.
"Slow Dev" button: Use when you have audio drops on slow mobile devices (e.g. old iPad).
Uses single color in spectrum and slower waterfall speed.
"colormap" & "contrast" menus: beginnings of waterfall colormap control. Work-in-progress.
"spec filter" menu: variable spectrum time constant so decay time can be varied.
Add URL parameter to set initial waterfall speed:
wf={0, off, 1, 1hz, s, slow, m, med, f, fast} e.g. kiwi:8073/?wf=1hz
Fixed problem with NDB database lookup not working.
Removed less buffering and compression buttons from Audio tab until they are working.
Not a big problem, I love the new UI. Thanks!
iPad version: iPad Air 2
Os: 11.2.1
Huub
