Entering FM mode in dx.json causes a crash [fixed in v1.152]
edited December 2017 in Problems Now Fixed
Hi Folks,
Avoid putting "FM" as a mode into your dx.json marker file. It causes a crash. I tried to put in 29.600MHz FM calling as a marker.
You did backup your dx.json file before editing didn't you..?
73s, Rob.
    edited November 2017
    You want "NBFM", not "FM". In v1.152 this will no longer crash but just default to AM mode.
  • Ah Thanks,
    I will go back and change it. As no markers are entered in that mode as standard, there was no "templates"!
  • I'll add this for the benefit of anyone else reading. Remember that it may be simpler to use the user interface to add or modify just a few entries rather than editing the dx.json file directly. Just shift-click in the label area, give the admin password if requested, and fill-in the fields of the panel that appears.
