Inactivity timeout not timing out [it was okay after all]
Hi folks,
My inactivity timeout is set to 25 mins. But it has stopped timing out, with people staying logged in for many hours. Has anyone else noticed this problem?
I tried changing the timeout to 20 mins but it was still the same. Using V1.146.
Thanks,
Rob.
Thanks,
Rob.
I have not edited the kiwi.config manually, and the single IP command should not be enabled here. My system runs off a solar panel, and due to the winter has only been swithed on part-time.
Anyway I did a beagle rebot, and will leave it on until the battery times out...
73s, Rob.
will try and report back ASAP.
-Rob
Silly me it does time out, I don't know how that box got zero'd
Inactivity does time out also.
-Rob
