Linear Power Supplies.
I got two linear power supplies from Seller sep_store on Ebay, great to deal with and the power supplies are very well built.
I got one for the KiwiSDR and the Broadband Modem and the difference is amazing. Night and Day !
Now I have an issue where my electric car charge point is causing a high pitched noise intermittently throughout the MW band and maybe elsewhere, I'm working tonight so shouldn't be heard for the next 12 hrs at least until I get home after night shift. But the very loud tearing noise associated with those filthy switch mode supplies is gone.
Let me know what ye think.
sep_store has lots of linear supplies listed, could you mention which one(s) you purchased please.
Thanks,
GaryG
I just emailed him what I wanted.
5v 2.5 amp and 12v 3 amp linear supply and whatever size plugs you need.
If you can think of anything else that would benefit from changing to linear then do it at the same time.
I am completely new to sdr. I started because I have tested my world receiver radio to still function properly (inherited from my dad: Sony ICF-SW7600G).
I like the idea about an sdr because of the view of the waterfall images. This enables me to identify stations quikly.
My questions are: Were can I order linear power supplies (low noise or audiophile) from germany?
I find it a bit complicated to contact the seller from an ebay shop and wonder why he does not offer the versions directly.
First I'll have a look at the Acopian 5EB250 but I also need a PSU for my Boni Whip antenna that I have purchased :-)
Thanks, Lothar
I just power my Bonito FX from the USB port on the Kiwisdr. Saves needing another supply.
I found contacting the seller Sep_Store on eBay quiet simple, it might take time to reply so get as much as you can think of sent in the first message.
That is now ordered :-)
If I cannot wait, then I may use my labour linear psu with a 5V 3A and two variable with up to 5A. Just to be extra sure about voltage settings and polarity :-)
