Kiwi and Ethernet Problem? [fixed with Beagle replacement]
Yesterday unhooked the Kiwi to chase some noise I've been looking at for a while. After unhooking and moving a few things around now I can't get it to work again... as in.. won't connect to the network and the lights aren't flashing on the Beagle Ethernet plug.
I have checked the E cables, switched E cables, all good.
Rebooted the router a few times. Took the E switch out of the equation
Reinstalled the software, more than once, even D/L a new version and burned it to the SD card.
Took it to work and hooked up to my router and still won't connect or light the Ethernet connection lights. Although the Beagle does have the one LED flashing, one closest to edge of board.
So, my guess is either the software is not loading, which I will try again with a different SD card or when moving yesterday (humid day lower chance of static) I zapped the Beagle.
Any ideas appreciated.
Thanks, Rich, WD3C
