KiwiSDR setup - IP Port open but no access from outside [no NAT hairpinning]
Hello,
just installing KiwiSDR and configuring, local use is ok (as user and admin).
I have successfully open the port 8073 on my router and I have fixed the local ip address on my router.
On the "network" tab, I click the "check port open" button and it seems that's all is ok but I can not access my kiwiSDR from outside. I tried with my public IP and with "no-ip service", no luck.
I check the port with "http://www.portchecktool.com/" and the result is successfull, port is open.
I suppose I miss somewhat but ... what ...?
Any idea welcome
73's Pascal
https://forum.kiwisdr.com/uploads/Uploader/a0/96b357ba648fe1b777328897622f36.jpg
  • Well, it works ... since the begin I believe.
    When trying to connect from outside (with the public address), I was at home, same location.
    Trying from a remote location, it works without problem.
    73's Pascal
    edited September 2017
    Hi Pascal,
    Yes, unless your router implements something called "hairpinning" (https://en.wikipedia.org/wiki/Network_address_translation#NAT_loopback) it won't correctly process a connection attempt to your Kiwi public address made from your local network. That's why I added the "check port open" feature. Because the check is made from kiwisdr.com which is always outside your local network.
    I did not know about http://www.portchecktool.com/ so thanks for that -- very useful.
