Is there a howto for getting a kiwi on sdr.hu.
I've set up an account on no-ip. Obviously I have something set up incorrectly with my router, the no-ip, or the kiwi. When I check to see if I'm comnnecting, it is throwing an error message.
Thanks.
Thanks.
The DUC Domain switch solved that problem.
Now my server is listed but it won't open on my iPad, Safari is reporting a "server not found" when I click the link at SDR.hu
I can open the server on my iPad on the LAN so I know it's running.
Thanks for your quick response.
I had the Lennox vender here to install their VFD noise reduction kit. It did nothing. However, a ferrite bead on the blower motor leads worked like magic.
I still have a lot of noise between 2 and 5 MHz. I'm going to try moving it out of the house to a more electrically neutral out building.
Thank you again for your help. This is great support for a first class product that I would recommend to anyone.
Best,
Bill
I have toroids on the Ethernet cable and the antenna cable and a bead on the power supply cable. It's a linear supply I bought for about $50 on either Amazon or eBay.
I'm thinking about putting the bias T board (which is in an aluminum project box) in a steel waterproof box outside the house. I would put a splitter in it and run about 35 feet of buried cable out to the workshop. That would put distance and aluminum siding between the Kiwi and the switchers that dominate my house. I have a recording studio here.
I'm running all 75 ohm cable with f type connectors. Can a passive 2 way splitter be used or do I need transformers, too?
Even if the Kiwi doesn't work better in the shop, I have a couple of other radios I like for nostalgia sake that I'd use out there.
I will check out the transformers.
Thanks!
