V1.92 - Ant_switch extension no longer work
edited June 2017 in Problems Now Fixed
Hi John,
The new Fax decoder works really well :-)
But for some reason V1.92 has caused problems with the operation of the excellent (3rd party) ant_switch extension written by Kari.
The extension would seem to be activated as the ant_switch extension label is displayed alongside the list of user. However the left hand bottom grey panel doesn't slide away to be replaced with the ant_switch control panel.
  • Fix. On ant_switch.js file line 22 you need to change
     var firstChars = getFirstChars(data, 3);
    to
     var firstChars = arrayBufferToStringLen(data, 3);
    and then
    make stop
    make
    make install
    make start
    I updated my github repo. Should work with v1.92 now.
  • Hi Kari,
    OK - that fixed it :-)
    Thanks for the quick reply and even quicker fix !
  • Sorry, as I go through various parts of the code making improvements I also clean things up. And sometimes I forget that a change might impact an API used by external code. I'll make an alias for that routine so not everyone has to update from Kari's repo.
