1.84 - DUC Needs Restart?
I couldn't connect to my KiwiSDR (remote), and noticed when I connected locally that 1.84 was running. I wonder if there could be a correlation here - is it necessary to manually restart the DUC for the DDNS to work after an update?
Bjarne Mjelde
arcticdx.blogspot.com
the new version is 1.84.
A cut of the messages file for the 1.84 part will follow asap.
Phil
SERVER RESTART 00:50:49, see kiwisdr_log_210517_0130_1st_server_restart
5 minutes
DUC update enabled. I restarted with laptop disconnected from the 4G router. External
units could not connect to the Kiwi from this point, up until 01:26:47 when I
connected the laptop to the 4G router (local connection 10 seconds later and
external connection 01:32.29).
BEAGLE
REBOOT 01:41:15, see kiwisdr_log_210517_0146_beagle_reboot
I rebooted
with laptop disconnected from the 4G router. External connection made at
01:44:56, so all well.
SERVER
RESTART 01:53:27, see kiwisdr_log_210517_0158_2nd_server_restart
I restarted
01:53:27. Laptop connected to 4G router at 01:57:09.
Im
somewhat puzzled that the two server restarts produced such different logs. The
entries are additions to the log created by the reboot.
https://forum.kiwisdr.com/uploads/Uploader/76/69577a66f4f3d93f74c0721aeaaa29.txt
https://forum.kiwisdr.com/uploads/Uploader/02/cce1156dc893ec04879a77df0abcf9.txt
https://forum.kiwisdr.com/uploads/Uploader/d5/c9ff0801b7b2f749c14f8888ede4da.txt
