Default colormap [added in v1.414]
Would it be possible that from the admin page I could define "default colormap"? Why? Because I like the SdrDx so much that it would be nice to put it as default. It is the most usable in every way for me.
Pekka
Pekka
my_kiwi:8073/?cmap=5
(SdrDx is the 5th entry in the colormap menu) This only has to be done once because the value will be remembered in a browser cookie. Same as when you change the menu entry.Having a global colormap setting as one of the "user preferences" (future feature) would be better of course. Then it would be applied automatically to every Kiwi you visit (as a user) globally. Note that a new admin "initial colormap" config setting would only set the default for users (including yourself) that visit your Kiwi.
I'm reviving this thread because I wanted to set such a color map
how to create it? my fiddling with the colormap tab doesn't have that effect. Or maybe it would be possible to implement such a color bar for kiwi and adjust it freely, as in this example from my sdr transmitter
Regards
Have you tried using the Custom Colourmap Extension to define your own?
yes but drawing with lines or RGB points in this window didn't give me a satisfactory waterfall look, unless there is some other way that I don't know about?
Hi all,
I also like this color scale. May be, these profiles are a useful base ?
(The red end is a saturation indicator)
[ For my first post, congratulations and thanks to the -whole- "Kiwi" community, and first of all to John ! ]
73, Thierry.
