DUC Domain not working... & Adding additional user passwords for receivers?
I have Kiwi for about a week and still I am happy with it, but I am unable to set DUC Domain to work, I have NoIP account, but I am unable to have port opened to "internet".
Second thing I wanna add additional user passwords and have no idea how.
Thanks for any help
73
On the admin
connect
tab, when you clickClick to (re)start DUC
what message appears in thestatus:
field? Also, on thelog
tab, look for any obvious errors on lines starting withDUC:
So there are a million other networking-related issues you have to consider. Have you opened port 8073 on your router? (to allow incoming connections) On the admin network tab try using the
Auto add NAT rule on firewall/router
button, but this may not always work.Is this a residential Internet connection where your ISP could be actively blocking incoming connections?
I've enabled Auto add NAT rule, but not worked at, all I created port forward in my router, but i tried it even in my fiver optic modem settings, I have not idea how to set this up, no matter what i do, I have always 2x NO.
Residential ISP? If so they're probably blocking incoming connections.
If you've forwarded the port manually there is no need for the auto NAT thing. It's just more convenient. But it may require UPnP to be enabled on the router.
I had UPnP enabled, I have no idea how cain i fix this... Any other options?
I sent you an email.
