Kiwiclient & Python 3.10.4 on Linux (workaround)
after an OS upgrade I'm now facing this problem trying to run any of the kiwiclient utilities:
Traceback (most recent call last): File "/home/giuliano/kiwiclient/kiwiclientd.py", line 20, in <module> from kiwi import KiwiSDRStream, KiwiWorker File "/home/giuliano/kiwiclient/kiwi/__init__.py", line 8, in <module> from .wavreader import * File "/home/giuliano/kiwiclient/kiwi/wavreader.py", line 11, in <module> class KiwiIQWavReader(collections.Iterator): AttributeError: module 'collections' has no attribute 'Iterator'
Any idea? Last resource would be to revert python back to a previous working version.
Thanks a lot.
In the file
kiwi/__init__.py
comment out (add a "#" to the beginning) of the line that says:from .wavreader import *
i.e. make it:
#from .wavreader import *
Not a real solution to the problem, but should be enough to get you going as
kiwi/wavreader.py
is not used for normal operation of the kiwiclient tools.It works again.
Thanks a lot, really.
Giul
