Kiwiclient & Python 3.10.4 on Linux (workaround)
edited December 2022 in Problems and Issues
after an OS upgrade I'm now facing this problem trying to run any of the kiwiclient utilities:
Traceback (most recent call last):
 File "/home/giuliano/kiwiclient/kiwiclientd.py", line 20, in <module>
  from kiwi import KiwiSDRStream, KiwiWorker
 File "/home/giuliano/kiwiclient/kiwi/__init__.py", line 8, in <module>
  from .wavreader import *
 File "/home/giuliano/kiwiclient/kiwi/wavreader.py", line 11, in <module>
  class KiwiIQWavReader(collections.Iterator):
AttributeError: module 'collections' has no attribute 'Iterator'
Any idea? Last resource would be to revert python back to a previous working version.
Thanks a lot.
    edited September 2022
    In the file kiwi/__init__.py comment out (add a "#" to the beginning) of the line that says:
    i.e. make it:
    #from .wavreader import *
    Not a real solution to the problem, but should be enough to get you going as kiwi/wavreader.py is not used for normal operation of the kiwiclient tools.
  • It works again.
    Thanks a lot, really.
    Giul
