Kiwi 'busy' when it's not [fixed in v1.561]
edited September 2022 in Problems Now Fixed
Hi all, I noticed my Kiwi kicks me off after a few seconds with the message below, even when there are no other users connected.
Any ideas why please?
  • On the admin page, control tab, what value is set for the menu called Number of simultaneous channels available for connection by non-Kiwi apps ?
    Are you accessing this Kiwi from its local network or not?
  • That was set to none.
    I was accessing NOT from its local network.
    Thanks
    A
    As a short term workaround set that value to anything but none.
    The explanation is a bit complex. It has to do with the measures taken to combat the "bot" connections most public Kiwis see.
  • Okay, the next release will have a fix such that you can return the setting to none.
