Kiwi 'busy' when it's not [fixed in v1.561]
Hi all, I noticed my Kiwi kicks me off after a few seconds with the message below, even when there are no other users connected.
Any ideas why please?
On the admin page, control tab, what value is set for the menu called
Number of simultaneous channels available for connection by non-Kiwi apps
?Are you accessing this Kiwi from its local network or not?
That was set to none.
I was accessing NOT from its local network.
Thanks
A
As a short term workaround set that value to anything but
none
.The explanation is a bit complex. It has to do with the measures taken to combat the "bot" connections most public Kiwis see.
Okay, the next release will have a fix such that you can return the setting to
none
