Problem connecting to listen online [ip blacklist issue fixed in v1.539]
2»
  • Okay, v1.539 is out which should fix this problem for most Kiwis.
    Go to rx.kiwisdr.com. Type v1.539 in the search box. You should be able to connect to most every Kiwi running v1.539 because it will have auto updated to a newer blacklist which does not include your ip address. Hopefully the Kiwis you are most interested in will auto update to v1.539 and get this fix.
  • Well thank you very much, I'm away for the weekend, but will check as soon as I get home.
    73, VE3TCY
  • Just tried it, and it works like a charm.
    Thank you for helping me out on this,
    I wasn't sure if I was doing something wrong at my end.
    73
    VE3TCY
