Throttle down fan inside aluminium case
Hi everyone
Anyone tried to solder a resistor in series to the fan, to slow the fan down a little bit so that the fan doesn't make so much noise?
Does anyone operate the KiwiSDR without fan at all?
Thanks, Simon
  • It is already running under voltage so if it is noisy it might be wear.
    You could peel the sticker off the fan and oil the bearing/shaft.
    I have only run the Kiwi+Beaglebone without the fan in another case (closer to the BeagleBone and lots of metal). A lot depends on the ambient temperature, if it is in a cool room I would think it will be OK but 30C or more not (just a wild guess).
  • Stu's suggestion of peeling back the label and lubing the bearing is really good advice.
    I was consuming fans about every 6 months. They now run much quieter and I haven't had to replace one since doing this.
