I've been locked out of kiwisdr.com
I'm no longer able to connect to kiwisdr.com, with any device coming from my WAN IP., Has my ip been blacklisted?, for how long?
    edited March 2022
    Yes, that's possible given all the ip blacklisting that's been going on lately. Although we've tried to be careful to limit the ip ranges to e.g. only cloud providers and not ISPs.
    What's your public ip? Email it to support@kiwisdr.com if you don't want to give it here (presumably your mail provider will be able to connect to kiwisdr.com even if you can't).
    Also, are you using a VPN? Who with?
  • There are no ip blacklist entries for your ip address.
    The only thing I could think of is that kiwisdr.com (the website) still uses http:// whereas the forum does not. Could something have changed on your network not allowing connections to insecure sites? Try http://ogdenarc.org as this is the only site I found quickly in my history that is still insecure.
  • oh right ok will try...
    I'll have to wait till i get home..though. This morning could not connect to kiwisdr.com even with my phone while still on same network...so after a reset of router and still with same problem...which led me to believe maybe I got myself blacklisted while banging away at remote access ....
    thank you,
    will keep you posted on progress.
    edited March 2022
    I've traded email this morning with someone having this same problem. It turned out to be the old Comcast/Xfinity security "feature". It happened after they switched to using a newer Xfinity "xFi" modem. Follow the instructions here to fix: https://forum.kiwisdr.com/discussion/comment/9770/#Comment_9770
  • Was there ever any resolution of this?
