Stuck resolutely at V1.470 [fixed]
edited December 2021 in KiwiSDR Discussion
Hi folks,
Despite doing...
cdp
m INSTALL_CERTIFICATES
update_fix
... many times or doing the admin page update my system is still stuck resolutely at V1.470. Tried switching 'Automatically install...' on and off but no difference either.
I expect it needs something more drastic to shift from 1.470. Any clues please, anyone?
  • are you able to ssh ans sudo to root? If so, this may do it
    cd [goes to /root]After rebooting from the update login again and from a root shell do:
    cd [goes to /root]
    cd Beagle_SDR_GPS
    make clean
    make
    make install
  • edited December 2021
    It might be disk full, corrupted downloads etc.
    There are other threads on here and I will look for them, that contain the fixes in those cases from John, but if the Kiwi is readily accessible to you, I'd consider a fresh install from original SD card and allowing it to update itself. That is a very basic method and obviously backup all customisations first even if only screen printing each tab. I say that as I see little downside to it and repairing a stuck one is probably most safely down by JKS who may still be enjoying some rare down time.
    E.G. http://forum.kiwisdr.com/index.php?p=/discussion/comment/12826/#Comment_12826
  • Yes, I looked exhaustively through all the 'stuck' threads.
    The original SD is long since lost/overwritten as this kiwi was working since 2017. I keep 2 rotating backups. After looking through forests of messages generated by make clean/make/make install I found a message to run this instruction:
    dpkg --configure -a
    ... and after doing the 3 steps again it finally updated! Time will tell if it ever makes it to V1.483...
    73s, Rob.
  • Better do that backup, but tomorrow, its late Boxing day in the UK.
  • We've seen this a few times, where the filesystem is so badly damaged that the package system fails to run without manual intervention to repair it.
  • As mine was running since 2017, and outlived an Apple Macbook pro, not surprising there is the odd glitch!
