DANGER: DO NOT do a manual Debian/Linux upgrade to your Kiwi! (update: but it's okay now)
We're not talking about the Kiwi auto-update process. That feature is perfectly fine and will continue as usual.
We're talking about people who manually update/upgrade the underlying Debian/Linux system on the Kiwi by logging into the Beagle as root and running, for example, the "apt" command. Please don't do this. We only validate specific Debian distributions. If you update manually you run the risk of "bricking" your Kiwi server. That is, downloading something causing an unexpected side-effect which prevents the Kiwi server from running. This will stop further auto-updates and will require a manual intervention to fix. Possibly by re-flashing your Beagle using the Seeed SD-card and losing your entire Kiwi configuration (unless you've backed up).
This is exactly what has happened since a change was made in late February by one of the Beagle developers that made its way into the Debian update stream. We've identified the problem and have asked them to make a change. But it is not clear when this might happen. If you have a Kiwi in this condition then please use the following workaround:
Symptom: The Kiwi server won't stay running. The log shows it just crashes and restarts over and over again with the error "SYS_PANIC: open spidev".
Workaround:
1) ssh/PuTTY into your Kiwi Beagle as user "root" (no password).
2) "cdp" Change to Kiwi build directory.
3) "up" Manually pulls the latest version from Github (v1.175 or later) and builds it.
4) When that's done do "cd unix_env/bb.org-overlays"
5) Type "./install.sh" (note the "dot" before the slash)
6) When that's done type "reboot"
Now the Kiwi server should run after the reboot.
If you upgrade from here things will break again until the Beagle developers can implement a permanent solution.
I tried to do this install under the Console in the Kiwi but that does not work.
When I connected to the Kiwi with SSH/Putty the installation run perfectly!
Is it safe to update the linux kernel?
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Kernel_Upgrade
Good luck, and please let us know what happens. Be careful you are updating to a kernel that is compatible with the Debian disto you're running.
Good news is, that 4.19.50-ti-r20 is booting and the usb stick works on 5 GHz.
Bad news is, kiwid doesn't start: Then it hangs.
Reason for it presumably being: https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Where_did_the_slots_file_go.3F
It's not urgent for me. But in long term it might need an adaptation, as debian jessie support will end 30/6/2020.
Guess what I just discovered? For all of you who upgraded your Kiwis beyond the stock Debian 8.5, and then did backups to an sd card, all those backups are UNUSEABLE as a recovery re-flasher by ANY version of BeagleBone Debian. Those cards will not boot and re-flash your Kiwi like they're supposed to.
Kiwi release v1.334 fixes this issue provided you make new backups using v1.334 or any future release. Out of the 400+ public Kiwis 60 of them are running Debian 8.6+ So this is not a small problem. PLEASE wait for the update and make new backups!
What happened? Well, sometime after Debian 8.5 the mkfs.ext4 utility that creates "ext4" format filesystems used on sd cards and the Beagle on-board eMMC was changed to use 64-bit addressing to support huge filesystem sizes. That's fine. But the problem is that uBoot, the little program at the beginning of every bootable device, was not changed because that's not part of a Debian upgrade. That's a BeagleBone distro issue. All of this was discovered by the Beagle folks back in 2016. And Beagle distros that used Debian 8.6+ made sure to add an option to mkfs.ext4 preventing the use of 64-bit addressing as a workaround until uBoot eventually gets 64-bit support.
But just upgrading Debian alone beyond 8.5, without the benefit of the associated Beagle distro, doesn't get this workaround. I spent a long time trying to figure out why sd cards built with Debian 8.6+ wouldn't boot. They looked fine when inspected using Debian itself. It wasn't until I learned how to inspect an sd card filesystem from uBoot that I saw they were corrupted from uBoot's point of view.
To do this login as root using ssh/PuTTY and use the following commands. (this can not be done from the Kiwi admin console tab)
If you haven't logged in this way in a while remember that your Debian root password has likely been changed to either the Kiwi admin password or the Kiwi's serial number if no Kiwi admin password has been set. The Debian root password has not been touched if you had set it to something other than the default of having no password.
See this post for details: http://forum.kiwisdr.com/discussion/1801/v1-354-security-improvements-debian-root-password-no-longer-unset-blank A few minutes after the reboot the Kiwi server should be responding again. If you login to the Beagle and type the "dog" command you should see: There is still the open question of how the Kiwi distribution, and thousands of Kiwi customers, will migrate to the current Debian 9 (Stretch) and/or Debian 10 (Buster) releases which are available for the Beagle. This needs time for research as there are many issues involved.
Is this procedure still valid?
During the 'pkup' step I received:
I have stopped at this point.
fyi:
This is pretty much an "out of the box" Seeedstudio kiwi that has been configured in the usual way. I haven't done anything particularly adventurous yet.
It's being worked on apparently: https://github.com/nodesource/distributions/issues/1266
Thank you.
On that same thread I have found and tested a safe work-around to this issue.
The amended procedure to use is:
I upgraded from Debian8.5 as shown above directly to:
Cheers
I also updated my kernel to 4.4.155 to install RTL8811au wifi chipset, now all of my kiwi's working over wifi :)
Thank you @jks for all your work!
Aurel.
v1.486 January 18, 2022 Support for Debian 10 (Buster) on BBG/BBB.
How to proceed to migrate to Debian 10 (Buster) on BBG?
I'm working out a procedure right now. The upgrade will not be an easy "one-click" process. It will be painful, involving ssh/PuTTY access to the Beagle Debian, sd card backup/download, etc.
