v1.465 - 2G_ALE
Nice addition to extensions.
However I have a problem. I have compiled a number of URLs in a text file. Refer attached.
Those given using UK and Norwegian sdrs open and run ok, but those three sdr's
in the Far East also using v1.465 only open the sdr but fail to open/run the 2G_ALE extension.
Question - does the v1.465 software have an enable/disable switch needed to be configured by the sdr owner/administrator?
Cheers DayW
Yes, admin has to...
Thank you
Cheers DayW
Typing errors - easily done
Try
Taiwan (Taipei) #1: (1.465)
http://jplin53a.proxy.kiwisdr.com:8073/?ext=ale,4216.25,6281.75,8396,s:1.5
Hokkaido (1.465):
http://sdrhkd.ddns.net:8073/?ext=ale,4216.25,6281.75,8396,s:1.5
Chongzou (1.465): Not available when I tried it.
http://nnsdr.proxy.kiwisdr.com:8073/?ext=ale,4216.25,6281.75,8396,s:1.5
[jks: edited so links work when clicked (due to crappy forum software)]
Extensions are enabled by default. So an admin does not have to explicitly enable them on the admin page, extensions tab. So most public Kiwis should have the ALE extension available. The easiest way to tell if an extension is enabled is to see if it is greyed out in the extension menu on the user page.
