Filesystem is FULL on my KiwiSDR [fixed]
edited September 2021 in Problems Now Fixed
Installed version: v1.432, built Feb 11 2021 00:55:18
Cannot build, filesystem is FULL!
root@kiwisdr:/# df -h
Filesystem   Size Used Avail Use% Mounted on
udev       10M   0  10M  0% /dev
tmpfs      99M 8.3M  91M  9% /run
/dev/mmcblk1p1 3.5G 3.3G  24M 100% /
tmpfs      247M   0 247M  0% /dev/shm
tmpfs      5.0M   0 5.0M  0% /run/lock
tmpfs      247M   0 247M  0% /sys/fs/cgroup
root@kiwisdr:/# du -sh
/usr/bin/du: cannot access ‘proc/24692/task/24692/fd/3’: No such file or directory
/usr/bin/du: cannot access ‘proc/24692/task/24692/fdinfo/3’: No such file or directory
/usr/bin/du: cannot access ‘proc/24692/fd/3’: No such file or directory
/usr/bin/du: cannot access ‘proc/24692/fdinfo/3’: No such file or directory
0 dev
0 proc
0 sys
4.0K ID.txt
4.0K media
4.0K mnt
4.0K nfs-uEnv.txt
4.0K srv
16K lost+found
28K home
40K tmp
2.4M opt
3.3M etc
3.6M sbin
5.8M bin
8.3M run
21M boot
78M var
97M lib
852M usr
2.3G root
root@kiwisdr:/# cd root/
root@kiwisdr:~# du -sh
4.0K build.log
4.0K ovh-update.sh
92K extensions
596K KiwiSDR-antenna-switch-extension
26M kiwi.config
29M build
2.2G Beagle_SDR_GPS
root@kiwisdr:/usr# du -sh
4.0K games
4.0K src
3.4M sbin
39M bin
40M local
44M include
220M share
507M lib
There are no large log files. What can I do in this case? Any advice ?
  • 2.2G Beagle_SDR_GPS
    That's the problem. It should be < 250 MB at most. Use the alias du for a nice sorted list of file/dir sizes and du. for the size of the current directory.
    So for example on one of my Kiwis:
    root@www:~# cdp
    root@www:~/Beagle_SDR_GPS# du.
    237M .
    0 d
    0 g
    0 kiwi
    0 n
    0 ng
    4.0K config.h
    4.0K dl
    4.0K k
    4.0K _LICENSE
    4.0K other.config
    4.0K RASPBERRYPI
    4.0K types.h
    4.0K up
    4.0K update_fix
    4.0K valgrind.h
    8.0K bits.h
    8.0K _COPYRIGHT
    8.0K kiwi.h
    8.0K Makefile.comp.inc
    8.0K README.md
    12K CROSS_COMPILE
    12K kiwi.config
    16K arch
    16K main.cpp
    44K Makefile
    56K ui
    100K init
    104K CHANGE_LOG
    104K net
    160K e_cpu
    292K support
    328K pru
    488K platform
    544K verilog
    652K gps
    1.9M tools
    2.1M KiwiSDR.rx14.wf0.bit
    2.1M KiwiSDR.rx3.wf3.bit
    2.1M KiwiSDR.rx4.wf4.bit
    2.1M KiwiSDR.rx8.wf2.bit
    3.9M verilog.Vivado.2017.4.ip
    5.6M pkgs
    5.7M rx
    8.9M unix_env
    9.3M web
    16M extensions
  • edited September 2021
    root@kiwisdr:~/Beagle_SDR_GPS# du
    0	d
    0	g
    0	kiwi
    0	n
    0	ng
    4.0K	config.h
    4.0K	dl
    4.0K	k
    4.0K	_LICENSE
    4.0K	RASPBERRYPI
    4.0K	types.h
    4.0K	up
    4.0K	update_fix
    4.0K	valgrind.h
    8.0K	_COPYRIGHT
    8.0K	kiwi.h
    8.0K	README.md
    12K	CROSS_COMPILE
    12K	kiwi.config
    16K	arch
    16K	main.cpp
    40K	Makefile
    56K	ui
    84K	CHANGE_LOG
    96K	init
    108K	net
    172K	e_cpu
    240K	support
    328K	pru
    484K	platform
    524K	verilog
    652K	gps
    1.8M	KiwiSDR.rx3.wf3.bit
    1.8M	KiwiSDR.rx8.wf2.bit
    1.9M	KiwiSDR.rx14.wf0.bit
    1.9M	KiwiSDR.rx4.wf4.bit
    1.9M	tools
    2.1M	verilog.Vivado.2014.4.ip
    3.6M	verilog.Vivado.2017.4.ip
    5.6M	pkgs
    5.7M	rx
    6.9M	extensions
    8.4M	web
    24M	unix_env
    root@kiwisdr:~/Beagle_SDR_GPS# du.
    2.2G	.
    This is strange.
    du. - shows 2.2G., but sum of files du approximetly 100 MB.
    Maybe somewith wrong with files system ?
  • Try:
    cdp
    cd .git
    du.
    la
    I'll bet for some reason you have huge files in the "hidden" .git directory. Although I don't understand why that would be.
  • To recover from this you can simply remove the directory entirely, reclone and then rebuild. This should work even if you are connected via the admin page console tab because the system is running from the installed image and not from anything in ~/Beagle_SDR_GPS.
    So try:
    cd
    rm -rf Beagle_SDR_GPS
    df . [should be lots of free space now]
    gclone Beagle_SDR_GPS
    cdp
    update_fix
    When it finishes restart using the restart button on the admin control tab. Or if connected via ssh use the ku command.
  • Thanks. Fixed.
