iOS - no Your name or callsign -field [fixed in v1.431]
edited February 2021 in Problems Now Fixed
Myself and a few other kiwisdr-hosts around here are having a campaign with message 'fill the Your name or callsign -field - we like to serve people, not just ip-addresses'.
But, it seems that in Apple iOS-environments (with safari and chrome at least) you just can't follow that request - that input field is not shown to the user at all!
Ok, then i also checked if it is possible to give it as an URL-parameter. No, it isn't.
Any ideas for cure?
73, Jukka
  • In v1.431 you can specify the name/callsign in the URL, e.g. "my_kiwi:8073/?u=my name" "user=..." also works.
    With narrow screens sections of the top bar are removed from display. First the time/OpenWebRX section on the far right. Followed by the name/callsign field and finally by the operator info field (if present) in the middle for the narrowest of screens. Obviously this could be handled better with a proper mobile UI.
  • Thank you very much for paying attention to this.
    73, Jukka
  • oh2bua a question how i must set this when i will have 8 users now i have by 2 normal waterfall
    by 3 it says ftt configuration and got a wide line thatcant move it say its locked
    you know how ?
    thanx :)
    i have set more receivers
