Noise Filter
Can someone point me in the direction where I can find instructions on how to configure the Noise Filter? I've played around with the settings quite a bit and have come up with nothing useful. I did a few Google searchs and found nothing there.
Basically, all I want to do is kill off the harshness of the static. Something that will make speech easy to hear. Kind of just taking the edge off of it.
What mode?
I'm not aware of a good guide but try this
If you a have a local Kiwi, or not busy public one, open two connections at the same time (in two browser tabs) and with headphones using the "Audio tab" - "Pan" move one audio left, one right so that you have the same tuned signal and mode in each ear.
The from the Audio tab select "WDSP" - "More" - "Denoiser" on one channel, "Spec" - "More" - on the other, reduce the "Active SNR:" to something that suits the signal level.
Compare results.
There might be a slight echo affect as the two channels are out of sync but it should give fast comparative results.
Thanks for the reply! I will try that.
What I want to also find out is what is wdsp, LMS, spec, etc. What do they mean and what do the various sub-settings mean/do? I'd like to learn what they are now how changing the setting effect the audio either by reading or doing I guess.
I assume that if (when) I totally screw up my audio, I can deleted the cookies are be set back to factory settings?
Thanks again!
