No audio or frequency selection? [fixed in v1.421]
Please help: I got brand new KiwiSDR online yesterday and it worked fine, but during the night it has gone to a mode, which doesn't allow frequency to be selected and there is no audio and waterfall shows no signals. I have booted everything, power switched on and off, forced build etc, I don't know what to do. http://185.89.55.189:8073/
Thanks, Mauno
Thanks, Mauno
But if you look at the browser console you can see right away that there are serious problems. I don't know why yet.
But the larger issue is this: it appears that none of the "tasks" within the code are running, i.e. sound, waterfall, GPS tracking. This is totally bizarre. I can't imagine off hand what's going on. And that thing about typing something in the frequency box and having it appear appended to a reloaded URL is totally bizarre too.
Every time I try and take a vacation we get stuff like this..
Mauno, did you change anything? I would really like to understand the actual problem here.
And also appends the well-known DNS server 1.1.1.1 to /etc/resolv.conf so that if your primary (e.g. DHCP-supplied) DNS is not responsive the backup 1.1.1.1 should answer.
Let me understand the last problem please: on the admin page "config" tab you switched "External ADC clock?" from "No" (default) to "Yes" without actually supplying an external clock to the J5 connector? Well, that would explain a lot. Maybe I have to add a "missing clock" circuit now to the FPGA.
The second line I don't understand.
Yes, I switched External ADC clock to Yes, because in my tired mind when calibrating I somehow connected the additional GPS receiver and external ADC clock (well, GPS receiver gives time :-)) with each other, without understanding what an ADC clock is. Yes, a dangerous button.
I will add that the same effect causes NO error in html, only incorrect entry by the administrator in the Config tab, if in the "Waterfall min (dBFS, fully zoomed-out)" window you enter the same or higher value as in the "Waterfall" window max (dBFS) "eg: -105 then Kiwi causes the browser to freeze or slow down but only for normal users. If you are an admin and you start your kiwi with the browser in which you entered and remembered your password, you will fire it without any problem. Additionally, ghosts marked as "(no ident) (unknow location) 1000khz AM" will appear in the panel under the USERS tab for a few seconds and want to get to your Kiwi
Regards, Artur SDR Plonsk
