Alternative DRM schedule access?
Hi All
I run the online DRM database at the DRM Reception Project website, https://www.drmrx.org
I use this schedule to update my copies of Dream automatically (Dream reads the URLs directly).
I'd like to use the same database in my own KiwiSDRs, but I can't figure out how, if
it is at all possible, to stop them looking at the drm.kiwisdr.com database.
Anyone is welcome to make use of the schedules at drmrx.org.
73 Chris
  • Hi Chris.
    I did not know about this. I'm in the middle of getting a new release together, so let me try adding a database choice menu to the DRM extension UI. Should be relatively easy. Thanks for having a .cjson (JSON with comments) format file. That will make my job much easier.
    Cheers,
    John
  • Hi John - the syntax of my cjson may not be 100% correct at the moment. I just based it on what I saw in the stations.cjson files on my own Kiwis. Our "regions" are different to yours at the moment too. Not sure if that will be a problem. I'm happy to tweak the code I use, or add fields to the database, to make life easier all round.
    Cheers, Chris
