Pls help decipher the startup sequence
KiwiSDR work fine a couple of month, but today they lost.
After rebooting, it does not access the network, does not try to obtain an address, and is not available or ping at a previously configured address, but physically the LAN is normal.
I recorded a video showing the flashing sequence during the boot process.
Can we understand something from these LEDs?
What else can i do to restore access?
How do you know all these things? "does not access network, does not try to obtain an address" etc. Is this based on DHCP ip address assignment information from your router? How is the ip configured for your Kiwi? DHCP? Static? Is it using the proxy? Does it have public access setup? If so, what is the public ip or domain name so I can check the logs on kiwisdr.com for information.
My forum nickname is not associated with Kiwisdr
Kiwisdr was on ua3ahm.ddns.net with public access. ISP gave a dynamic white address.
SDR had an internal static address 192.168.1.200
But now it does not ping. And on the port of the router, to which it is connected, there are no incoming packets.
I will record a longer video.
This video shows what happens next.
UTC 05/Sep/2020 03:39:21 time when SDR stopped responding
In the past this has occurred for several reasons. Mostly because of damaged filesystems due to power outages. The only way to know for sure is to login to Linux directly using ssh or PuTTY and look at the logs. Login as root using a password that is either your Kiwi's 4-digit serial number or the Kiwi admin password (unless you have already set a separate Linux root password).
It's often easier if you open the ssh port on your router so I can ssh into the Beagle and look around myself. But you have to know how to do this on your router.
BUT you also said the Kiwi did not even respond to a ping at the local, fixed .200 ip address. This is not good. Do you have both yellow and green LEDs lit on the Beagle Ethernet connector? Does the green one flash as you are sending it ping packets? It is possible the Ethernet is damaged on the Beagle. Have you had thunderstorms/lightning in you area in the past week?
Both yellow and green ethernet LEDs are on, green rarely flash. But dlink according to statistics accepts no packets from kiwisdr.
It remains only to dismantle everything and stick it into USB?
I just coincided bought new BBB, try to install kiwisdr on it and have some troubles with this, need to create new topic?
Am attaching console output. As I understand it, I need to free up space on mm?, but I don't know what exactly can be deleted.
Can you help me?
Can you help me?
Can you help me?
Can you help me?
And there is no way to delete posts
https://forum.kiwisdr.com/uploads/Uploader/d7/45efcbb974a4987a0a69a837808712.txt
I don't know why your disk is full. According to df you have a 4GB Beagle. There should be plenty of free space. Here's mine after a full Kiwi install: Look for large log files in /var/log. Remove them then restart.
The problem is that now you have these half installed packages like Clang. I don't know what will happen if you free up space then try and reinstall the Kiwi software. The package installs might fail.
There is something else that isn't right. At the top of that attachment it says the Linux kernel is 4.9.78-ti-r94. But the Debian distro used by the Kiwi software uses kernel 4.9.78-ti-r25. Does that Beagle have the distro installed that has the full window system? If so that's why you have no free disk space. The Kiwi uses the console-only distro. What is contained in the /etc/debian_version and /etc/dogtag files?
You should really just re-flash that new Beagle from the recovery sd card supplied with your Kiwi and not use whatever Debian image was on it.
/etc/debian_version
9.3
/etc/dogtag
BeagleBoard.org Debian Image 2018-01-28
Recovery sd card lost in the Uglich swamps. Is any other method to recover?
Can i download img to new sd card?
Everyone seems to lose their sd cards. Making a new one involves a bit of pain. Instructions here: http://kiwisdr.com/quickstart/index.html#id-dload
