broken rx?
My KiwiSDR has developed a strange fault: when I select a station eg 197 khz (AM) I can hear that station but with a multitude of other stations in the background. There is no selectivity at all. GPS and other features all seem ok.
I use the device mainly for wspr and it appears to work fine.
Any ideas hat I might have blown up?
Regards
IK (G0WZM)
Regards
IK (G0WZM)
https://en.wikipedia.org/wiki/LuxemburgGorky_effect
More likely would be some sort of local IMD due to strong-signal rectification (your rusty rain gutter becoming a non-linear device is the usual example).
I used a Kiwi in Somerset and the signal sounded fine and was S9+35 (-40 dBm) which is strong but not extremely so.
Yes it was the local LW BBC transmitter I tuned in to when I first noticed things had gone wrong.
Regards
IK (G0WZM)
Is this Kiwi available on the net? A little listening and I could probably tell you more.
Also I did increase the length of the antenna recently, albeit quite low above the ground, so I will check again with a shorter wire
By the way this happens here a LOT if I don't have the BCB filter inline. It's nothing special, a "bare bones" labeled unit from EBAY for $9USD . It makes all the difference in the world . Without it the Kiwi is completely saturated with images here. That one cheap filter really works great.
I 2nd the idea of reducing antenna gain or maybe try an attenuator. See what effect a 10 or 20 dB pad has. I run mine with 3dB (or is it 6dB?) on it all the time because I get overload from AM BCB and SW BCB (the 6MHz stuff I think).
Keep us posted.
