cant log in to kiwi sdr
on Sunday evening the kiwi sdr was ok.
Since Monday morning 13 -7- 2020, we can no longer address the kiwi sdr.
The admin panel is also not approachable.
we sometimes get a message that we are using a browser with the wrong java script.
after several attempts we flashed the kiwi, but no access yet.
someone an idea what is wrong.
After a re-flash there is really no reason you shouldn't be able to contact your Kiwi with your browser unless you have browser or network configuration problems. What happens when you use any of the half dozen methods listed in the instructions to obtain the Kiwi's ip address? Does the Kiwi ip respond to a network ping command? What appears when you use "my.kiwisdr.com"? Can you ssh or PuTTY directly to the Kiwi?
Do you use DHCP from your router to assign the Kiwi its ip address or have you assigned a fixed ip address to the Kiwi?
now use a different password and it works again
ps: is it possible to place an analog S meter instead of a digital one.?
I did find an issue when the user password panel sits idle on the screen for too long without any password being entered. The 20 second timeout that catches Internet bots hanging Kiwi slots by making incomplete API connections was being incorrectly triggered for idle password panels. There is a separate 60 second timeout for this purpose. I added a message when this timeout occurs rather than just leaving the panel unresponsive. This change will appear in the next release.
