Wish List Item? S/N of current station
Knowing you are taking a break John, I really appreciate that you have continued to work on things that interest you!
I was wondering if it is possible to display somewhere the signal to noise of the selected station. It would be nice to be able to compare antennas etc to see if they are improving it.
Thanks,
Ken
Thanks,
Ken
S/N depends a lot on the kind of signal you are interested in, i.e., I don't think there is a generic solution.
You might have a look at the S/N data produced by the WSPR community, see
http://wsprnet.org/drupal/wsprnet/spots
http://wsprdaemon.org/graphs/index.html
The WSPR reporting has two different algorithms which provide two different estimates. This turns out to be interesting because the spread in those two values often gives insight into, say, thunderstorm influence.
It's a jungle out there...
Without knowing any specifics of the desired signal how about an approximation of SNR in the time domain by dividing mean value of the demodulated audio signal by the standard deviation of the signal measured within a certain time window.
