Whistle or tone when not tuned exactly - version v1.397 [fixed in v1.398]
Hi Folks,
Love my KiwiSDR. Had it about 9 months now.
I have noticed recently that I can hear a tone when I tune a station but it's not right on the frequency. I don't recall this in previous releases. For example, 11879.59 makes the tone but 11880 doesn't. It sounds like the beat frequency between the carrier and the offset of where the radio is tuned.
Power cycled and forced a software rebuild. No change.
Anyone else notice this?
Ken
Ken
Try cycling the mode button.
Things I'd check:
1. Try it on another SDR elsewhere, same frequency.
2. Monitor the tone with a phone app like Spectroid see if it changes with the tuning (same ratio)
3. try another station without any overlapping stations (even a very weak station carrier can be heard, think morse)
Assuming you are not sufferering overload it may be spikes from ADSL, Network or other clocks.
To look any further someone would have to be able repeate it elsewhere, on more than one or two frequencies.
Easiest way to confirm this is to check the beginning messages in the log tab on the admin page. You should see numbers for the I and Q balance that are either the default (-0.02) or roughly the same. Example:
It was at .05 for both, now showing DC_offsets: I -0.020019 Q -0.018597 after following the procedure mentioned.
Anyway, the bug will be fixed in the next release. Thanks for calling it to our attention!
