V 1.395 removing references to sdr.hu
On the stats tab there is a message saying "Try other kiwis on sdr.hu". I removed this according to jpe's post on Mar 21. Quoted below. Now showing sunrise sunset times.
"Displaying sunrise and sunset times at your Kiwi QTH in your Kiwi UI
jpe
March 21 edited March 21 in KiwiSDR Configuration and Operation
If you wish to show the sunrise and sunset times at the location of your Kiwi SDR, please remove all code in the Status field under the Webpage tab in the Admin interface, and replace it with the following HTML code:
In the example above, the la or the LATITUDE parameter in the URL is set to zero, as is the lo or the LONGITUDE parameter. You must set them to those of your QTH. Please note that southern latitudes are negative numbers as are western longitudes.
The sunrise and sunset times are all in UTC
73 Jari OH6BG "
jpe
73 Jari OH6BG "
I had edited one webpage tab and that was still pointing at the old address but others have been corrected without effort from me.
Good reminder to check so thanks.
I'll see where else I may have left old info.
-while checking-
One residual instance on the public tab
"e.g. when set to 0 and 30000 sdr.hu shows "HF""
This forum software is weird/unreliable. On my end your post has a timestamp and hour later than it should.
In /var/log/messages on daemon start, I get this line:
Jun 12 14:39:37 wikipi-2 kiwid: 00:00:07.455 ........ TIMEZONE: lat/lon from sdr.hu config: (52.660000, -8.550000)
Though you might like to know.
(I'm running this on a Pi3, if that's any relevance)
