Looking for Guidance [BBB vs BBG, enclosure]
edited January 2017 in KiwiSDR Discussion
Hi, I'm looking at buying the receiver as I can get the BB cheaper locally so I want to know which is the better BB to buy, Black or Green?  Also is there an enclosure for this offered separately?
Thanks,
Michael
hfaero.com
    edited January 2017
    BBB or BBG makes no difference to the Kiwi. So if you have a local source for the less expensive BBG you might as well get that.
    The enclosure shipped with the Kiwi kit version is the same as this: https://www.seeedstudio.com/Skeleton-Box-For-Beaglebone-p-1952.html
    Standard BB enclosures don't completely work because of the extra length of the Kiwi board (cape). But a lot of my development Kiwis just have the BBB/G attached to the bottom half of a standard BB enclosure, like a Hammond or Adafruit, with the top left off. Works great.
    If you want to use the GPS then any 3.3V active GPS antenna with an SMA-M connector will do. You can find them almost anywhere although Seeed does not currently sell separately the one packaged with the Kiwi kit. More info including power supply recommendations here: http://kiwisdr.com/quickstart/index.html
  • Thank you for that John, I'll start gathering the peripherals and order the rx board in a week or two. Is GPS mandatory
  • GPS is optional. It is used to calibrate the crystal oscillator to get the receiver exactly on frequency. But if the SDR is in a room with reasonable and relatively constant temperature this is not really a problem.
  • Cheers, thank you.
  • Does the BB need power as well as the 5v provided to the cape? i.e. do I need two power supplies?
    edited January 2017
    No, the BB gets power from the Kiwi board via the BB/Kiwi interconnect headers.
