ALE Scan option out of function from now [fixed in v1.810]
Dear all,
since a few days the sacnning funtion cannot be used anymore.
e.g. http://178.115.248.93:8073/?ext=ale,9000,1000,scan:1,log_time:4
was working yesterday without problems.
A lot of other SDR receiver with the same result since today...
Change after software update ?
73,
Bernd (DK9FI)
Hmm. Yes, seems to be a bug in the v1.809 software release. That's unfortunate.
I've fixed the problem. But I'm not sure when we're going to have a new release.
Hi all,
It seems that you can manually launch the scanning in the "local" menu, click on the "scan" line of the url list of interest. ( If you click the "stop" button then you can click "scan" as usual to restart.) (v1.809).
73,
Thierry
Thanks! I forgot that the URL scan list is also entered as the first entry in the local menu.
many thanks for very quick help!
It is working well in USB, not in LSB, no problem I think we can all wait for update.
By the way, if I set lock time in scan command line (,scan:1,log_time:4), why must I click again log option in the left field below?
73, Bernd
In addition to setting the logging interval with
log_time:N
you also need to set a record menu option that includes logging. Such as "log" or "r+l" (record + log). So in the URL...&rec:2&log_time:N
Sincerec:2
means the 3rd record menu entry "log" (counting from zero). See the ALE extension help panel.The "log" button is for forcing a log to be taken manually.
