v1.809
v1.809 April 5, 2025
The output from my.kiwisdr.com has been expanded to include additional information:
Proxy links in addition to local IP links if proxy mode is setup and running.
Connection type & status (i.e. settings on admin page "connect" tab).
Kiwi and Debian software versions.
Kiwi product model and Beagle type.
The Debian hostname is shown after the serial number if it has been customized from the
default "kiwisdr". Useful if you have multiple Kiwi on your network and you want to
distinguish them by name instead of solely by serial number.
Admin network tab has new field "Debian hostname" to complement the my.kiwisdr.com change above.
This changes the actual Linux hostname and is not just a Kiwi configuration parameter.
DX label fixes (desktop):
When an extension is open, and you click on a dx label specified to open the same named
extension, the extension won't get closed and re-opened. Instead, any new extension
parameters contained in the dx label are sent directly to the open extension for
further processing. Example: clicking on a different LF time station causes the
timecode extension to change its decoding setup.
Label only turns magenta (indicting extension will be opened on click) when mousing over
label _without_ a modifier key pressed (shift etc). For example shift-clicking a label
opens the label edit panel. So it doesn't make sense to be turning the label magenta
because an extension isn't going to be opened when you click it.
The DX help panel is opened if the cursor is in the label area and "h" or "?" pressed.
The stored DX database can now have a custom name, 15 chars max. (thanks Mauno WRTH)
Change the first line of the dx.json file from:
{"dx":[
to:
{"my-custom-name":[
If this is of interest you presumably already have a custom dx.json file you're loading
via the admin DX tab "import JSON" button. If not, just use the "export JSON" button
to download a copy of dx.json and use a text editor to make your changes.
The custom name will appear in all the usual places: The left end of the frequency
scale, the various database selection menus, etc.
When frequency scale offset is in use (i.e. using a downconverter) fixed broken behavior of:
"VFO A/B" button. (thanks F5AFY)
"Zoom-to-band" button.
"--- +++" buttons when frequency scale offset was not a multiple of 1 kHz.
S-meter URL query: Allow optional mode e.g. my_kiwi:8073/s-meter?14200usb (thanks F5AFY)
Prevent Beagle LED control conflict when admin backup function running. (thanks F5AFY)
Save/restore waterfall timestamp parameters in browser storage. (thanks nitroengine)
Removed debugging print causing lots of "AJAX_STATUS ..." messages in admin log when
wsprdaemon or similar application are in use. (thanks DL4ZBE)
Admin local blacklist now disallows entry of subnets which would otherwise exclude local
network addresses or the loopback IP address. (thanks G2YT)
When the "device preset" menu of the "Mouse wheel / trackpad setup" section of the user tab
is set to anything except "custom" the three fields below are disabled for input.
Although they still show what the preset values are. (thanks ZL2P)
