FPGA not responding: 0xffff
Installed http://kiwisdr.que4.org:8073/ in ~2017 and has been running nicely until a few days ago.
Followed John's advice on rebuilding from August 2024:
....I think I see what's going on.
Since you have shell access to Debian/Linux maybe the easiest way is for you to do a manual update as opposed to figuring out how to setup router port forwarding. So try this procedure.
First, login as debian/my_serialnumber as you did before. The do a "sudo su" and use my_serialnumber again as the root password. Then use this command sequence:
cdp (changes to the directory /root/Beagle_SDR_GPS)
msd (stops the Kiwi server running; this command takes some time)
gup (updates the sources from Github to the latest version)
mc (clean up in preparation for build)
m (build -- takes 15 to 30 minutes)
mi (installs built system)
ku (restarts server after build)
60 seconds or so after the "ku" finishes the system should be working. Your DX label changes should not be affected....
So, ssh'd in and ran cdp; msd; gup; mc; m; mi; ku and the build looks good.
But got seeing this in the syslogs:
Jan 7 20:41:28 kiwisdr kiwid[19450]: Start kiwid: OK
Jan 7 20:41:28 kiwisdr kiwid[19450]: Tue Jan 7 20:41:28 UTC 2025
Jan 7 20:41:28 kiwisdr kiwid: 00:00:00.025 KiwiSDR v1.800 --------------------------------------------------------------------
Jan 7 20:41:28 kiwisdr kiwid: 00:00:00.029 compiled: Jan 7 2025 18:53:47 on kiwisdr
Jan 7 20:41:28 kiwisdr kiwid: 00:00:00.032 /etc/debian_version 8.5
Jan 7 20:41:28 kiwisdr kiwid: 00:00:00.032 Mongoose 5.6
Jan 7 20:41:28 kiwisdr kiwid: 00:00:00.113 reading configuration from file /root/kiwi.config/kiwi.json: 591 tokens (7.4k bytes)
Jan 7 20:41:28 kiwisdr kiwid: 00:00:00.116 reading configuration from file /root/kiwi.config/admin.json: 145 tokens (3.8k bytes)
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.504 EEPROM check: old format serial_no compatibility 13590 => 3590
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.507 serial number from EEPROM: 3590
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.510 model: KiwiSDR 1
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.510 reading configuration from file /root/kiwi.config/dx_config.json
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.511 reading configuration from file /root/kiwi.config/dx.json
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.538 DX: 872 label entries
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.542 DX: file = 872,db6868b3,52120
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.546 reading configuration from file /root/kiwi.config/dx_community_config.json
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.546 reading configuration from file /root/kiwi.config/dx_community.json
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.571 DX: 895 label entries
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.574 DX: file = 895,0898b73f,53552
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.578 .... firmware: SDR_RX4_WF4
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.578 .... firmware: rx_chans=4 rx_wb_buf_chans=4 wb_chans=0 wf_chans=4 gps_chans=12
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.578 .... firmware: RX rx_decim=5556 RX1_DECIM=926 RX2_DECIM=3 USE_RX_CICF=1
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.579 .... firmware: RX rx_srate=11998.902(12000) wb_srate=0 bufs=4 samps=170 loop=85 rem=0 intr_usec=14166
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.579 .... firmware: WF xfer=9 samps=911 rpt=50 loop=18 rem=11
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.579 .... webserver: listening on port 8073/8073 for HTTP connections
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.579 .... webserver: OK, port [::]:8073
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.829 .... ### open SPI_DEV /dev/spidev1.0
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.832 .... SPIDEV: max_speed 48000000 bpw 32
Jan 7 20:41:29 kiwisdr kiwid: 00:00:00.835 .... SPIDEV: spi_mode 0x0|0x0
Jan 7 20:41:29 kiwisdr kiwid: 00:00:01.000 .... firmware: /usr/local/bin/KiwiSDR.rx4.wf4.bit 32559
Jan 7 20:41:30 kiwisdr kiwid: 00:00:01.761 .... SPIDEV: spi_mode 0x0|0x0
Jan 7 20:41:30 kiwisdr kiwid: 00:00:01.874 .... FPGA not responding: 0xffff
Jan 7 20:41:30 kiwisdr kiwid: 00:00:01.977 .... SPIDEV: spi_mode 0x1|0x1
Jan 7 20:41:30 kiwisdr kiwid: 00:00:02.089 .... FPGA not responding: 0xffff
Jan 7 20:41:30 kiwisdr kiwid: 00:00:02.192 .... SPIDEV: spi_mode 0x0|0x0
Jan 7 20:41:30 kiwisdr kiwid: 00:00:02.304 .... FPGA not responding: 0xffff
Jan 7 20:41:31 kiwisdr kiwid: 00:00:02.407 .... SPIDEV: spi_mode 0x1|0x1
Jan 7 20:41:31 kiwisdr kiwid: 00:00:02.520 .... FPGA not responding: 0xffff
Jan 7 20:41:31 kiwisdr kiwid: 00:00:02.623 .... SPIDEV: spi_mode 0x0|0x0
Jan 7 20:41:31 kiwisdr kiwid: 00:00:02.736 .... FPGA not responding: 0xffff
Jan 7 20:41:31 kiwisdr kiwid: 00:00:02.839 .... SPIDEV: spi_mode 0x1|0x1
Jan 7 20:41:31 kiwisdr kiwid: 00:00:02.952 .... FPGA not responding: 0xffff
Jan 7 20:41:31 kiwisdr kiwid: 00:00:03.055 .... SPIDEV: spi_mode 0x0|0x0
Jan 7 20:41:31 kiwisdr kiwid: 00:00:03.169 .... FPGA not responding: 0xffff
Jan 7 20:41:31 kiwisdr kiwid: 00:00:03.273 .... SPIDEV: spi_mode 0x1|0x1
Jan 7 20:41:32 kiwisdr kiwid: 00:00:03.385 .... FPGA not responding: 0xffff
Jan 7 20:41:32 kiwisdr kiwid: 00:00:03.488 .... SPIDEV: spi_mode 0x0|0x0
Jan 7 20:41:32 kiwisdr kiwid: 00:00:03.600 .... FPGA not responding: 0xffff
Jan 7 20:41:32 kiwisdr kiwid: 00:00:03.703 .... SPIDEV: spi_mode 0x1|0x1
Jan 7 20:41:32 kiwisdr kiwid: 00:00:03.816 .... FPGA not responding: 0xffff
Jan 7 20:41:32 kiwisdr kiwid: 00:00:03.819 .... FPGA panic: code=6 FPGA not responding to ping1
Now stuck and site does not come up.
....Executing /usr/sbin/update-rc.d kiwid enable
make[2]: Leaving directory '/root/KiwiSDR'
make_install_binary DONE
make[1]: Leaving directory '/root/KiwiSDR'
root@kiwisdr:~/KiwiSDR# ku
systemctl --full --lines=250 stop kiwid.service || true
systemctl --full --lines=250 start kiwid.service || true
Thoughts? Is the FPGA broken?
Thanks, Cal
Chicago IL - 773-294-3368 - cthixton @ gmail.com
Yeah, that's not good. Try a full power cycle where it stays powered off for a good 30 seconds or so. We've seen a few come good after doing that (reason unknown).
If you're able, the other thing would be to check voltages and clocks on the Kiwi board as mentioned in the troubleshooting guide: Troubleshooting guide
The other thing worth trying is re-flashing the Kiwi from the current Debian 11 image since it looks like your Kiwi is still running Debian 8.5. That should have no bearing on the FPGA issue, but D8 is so old I don't trust it at all these days.
Re-flash instructions here: http://kiwisdr.com/info/#id-net-reflash
That LED pattern also means FPGA not responding: http://kiwisdr.com/info/#id-fpga
I would try a Debian 11 image re-flash first. Then check voltages/clocks.
Currently, this Kiwi is working again. So maybe an intermittent hardware problem (e.g. flakey ADC/GPS clock etc). Still Debian 8.5 and v1.800
