1.599 Backup [fixed in v1.600]
Hi
I wanted to backup my receivers, the card reaches about 10% and breaks the connection with the administrator's website. I waited 15 minutes for it to save although I don't know if the backup was finished, usually it never took longer. I removed the cards from all devices but they hibernated. LEDs are on The router sees all but does not respond to the administrator and user interface. I disconnected all the power for 15 seconds and the fun began, 2 started normally, 2 more did not connect to the router for about 3 minutes, the last kiwi did not respond to connecting the power for several minutes, it only started when I disconnected it from the power supply for 4 minutes. Now they work (modes #8 and #4 in different configurations as they should with autorun in mix FT8/FT4/WSPR where #8 as I noticed only fires #6 autorun leaving #2 free with a waterfall, which improves performance) I turned on another backup but only on one device and the situation repeats itself, only disconnecting from the power supply helps and the backup probably failed. Installed v1.599
    edited April 21
    BBG/B, AI or AI-64?
    What version of Debian? (e.g. 8 or 10).
    When was the last time you made a backup successfully and what Kiwi version was it running (approximate answer is okay).
  • Debian 8 (still) previous copy around 1.52 or 1.53
  • How large of an sd card? When you push the disk free button (yellow) on the admin console tab what's the output? E.g:
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/mmcblk0p1  3.6G  2.1G  1.4G  61% /
  • CONSOLE: open connection
    root@kiwisdr:~/Beagle_SDR_GPS# df .
    /dev/mmcblk0p1  3.5G  1.6G  1.8G  48% /
    all cards are 10class 16gb
  • Thanks for your effort, now it works perfectly
