v1.590: Spec AF, peak hold, admin console, Debian 8, IQ extension residual rotation
v1.589,590 Apr 1, 2023
  Workaround added for the IQ extension residual phase rotation problem. Details on the forum:
  forum.kiwisdr.com/index.php?p=/discussion/2852/unexpected-iq-phase-shift-in-gpsdo-kiwi/p1
  Debian 8 is now deprecated. Existing Kiwis using Debian 8 and a recent Kiwi software version
  will continue to receive auto-updates and don't really need to do anything.
  But re-flashing from the factory v1.2 image (on the supplied sd card) or from the old v1.390
  img.xz file no longer works as the Debian 8 repos from debian.org are now broken.
  However, if you're running Debian 8 you can choose to upgrade to Debian 10.
  Instructions are on the forum.
  Spec AF:
    Indented the maximum bandwidth edges and mark with red lines (thanks Paul).
    Moved the de-emphasis filter before the FFT-based passband filter so the effect of
    de-emphasis will now appear in the Spec AF display.
  Spectrum peak hold:
    In peak hold active mode a mousedown on P1 P2 for more than one second will clear the trace.
    Added border to peak buttons P1 P1 with colors matching the yellow/magenta trace color.
      Text colors similar to before: white=OFF green=ACTIVE orange=HOLD (was magenta)
    Fixed problem where activating peak hold didn't always work in until the second try.
  Admin console: Optimized ANSI color palette for increased contrast. For example a
    "nano /etc/ssh/sshd_config" is readable now (thanks Rob). Fixed other ANSI-related bugs.
