Setting up the Debian 10 Image on a BBG without the KiwiSDR Board
Hello,
I ordered a BBG and the KiwiSDR board. I received the BBG, but the KiwiSDR board is still on backorder and won't be here for several more weeks. But, in anticipation of receiving the board, I would like to get things set up, so I imaged the BBG with the Debian 10 KiwiSDR image, and rebooted. I can ssh into the BBG just fine, and it is seemingly operating normally; however, no matter what, I cannot get to the web interface admin page (LocalIP:8073/admin). I get the "ERR_CONNECTION_REFUSED" error.
I can see that the kiwid.service is running:
root@kiwisdr:/home/debian# systemctl list-units --type=service --state=running
UNIT                       LOAD  ACTIVE SUB    DESCRIPTION
avahi-daemon.service       loaded active running Avahi mDNS/DNS-SD Stack
connman.service            loaded active running Connection service
cron.service               loaded active running Regular background program processing daemon
dbus.service               loaded active running D-Bus System Message Bus
dnsmasq.service            loaded active running dnsmasq - A lightweight DHCP and caching DNS server
getty@tty1.service         loaded active running Getty on tty1
haveged.service            loaded active running Entropy daemon using the HAVEGE algorithm
kiwid.service              loaded active running kiwi daemon
rsyslog.service            loaded active running System Logging Service
serial-getty@ttyGS0.service loaded active running Serial Getty on ttyGS0
serial-getty@ttyS0.service loaded active running Serial Getty on ttyS0
ssh.service                loaded active running OpenBSD Secure Shell server
systemd-journald.service   loaded active running Journal Service
systemd-logind.service     loaded active running Login Service
systemd-timesyncd.service  loaded active running Network Time Synchronization
systemd-udevd.service      loaded active running udev Kernel Device Manager
user@1000.service          loaded active running User Manager for UID 1000
wpa_supplicant.service     loaded active running WPA supplicant
But, I'm wondering if I won't be able to do any config via the web interface until the actual KiwiSDR board arrives and is connected to the BBG. Is the KiwiSDR board required to actually configure and run the web interface (LocalIP:8073/admin)?
Perhaps I just need to be patient until the board gets here. 🙂
Thanks!
